Hover-1 XLS Brake Replacement
  1. Hover-1 XLS Brake Replacement, Front Brake: step 1, image 1 of 3 Hover-1 XLS Brake Replacement, Front Brake: step 1, image 2 of 3 Hover-1 XLS Brake Replacement, Front Brake: step 1, image 3 of 3
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Brake Replacement: step 2, image 1 of 1
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Brake Replacement: step 3, image 1 of 2 Hover-1 XLS Brake Replacement: step 3, image 2 of 2
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
Jonathan Hidalgo
575 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 23
All Time: 777
