Hover-1 Rally Acceleration Lever Replacement
  1. Hover-1 Rally Acceleration Lever Replacement, Acceleration Lever: step 1, image 1 of 1
    • Remove one 4 mm Phillips #1 screw located directly above the acceleration lever.
  2. Hover-1 Rally Acceleration Lever Replacement: step 2, image 1 of 2 Hover-1 Rally Acceleration Lever Replacement: step 2, image 2 of 2
    • Turn the right handle grip counterclockwise.
    • The right handle will disconnect from the handlebar, exposing the acceleration lever.
  3. Hover-1 Rally Acceleration Lever Replacement: step 3, image 1 of 1
    • Remove four 2 mm Phillips #00 screws located on the acceleration throttle.
  4. Hover-1 Rally Acceleration Lever Replacement: step 4, image 1 of 1
    • Pull the acceleration lever off of the handle.
    • The acceleration lever sits perpendicular to the handle.
Van Schneider
112 Reputation
1 Guide authored
Cal Poly, Team S7-G2, Regan Winter 2020 Member of Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Members
7 Guides authored
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 31
All Time: 2,043
