Hover-1 H1 Battery Replacement
  1. Hover-1 H1 Battery Replacement, Bottom Shell: step 1, image 1 of 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Battery Replacement: step 2, image 1 of 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Battery Replacement: step 3, image 1 of 2 Hover-1 H1 Battery Replacement: step 3, image 2 of 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Battery Replacement: step 4, image 1 of 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Battery Replacement, Battery: step 5, image 1 of 1
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  6. Hover-1 H1 Battery Replacement: step 6, image 1 of 1
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
Aaron Teh
442 Reputation
2 Guides authored
Cal Poly, Team S17-G6, White Fall 2018 Member of Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Members
7 Guides authored
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 185
All Time: 8,930
