Honda CSC29 Alternator Cover Removal
  1. Honda CSC29 Alternator Cover Removal, Alternator Front Cover: step 1, image 1 of 3 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: step 1, image 2 of 3 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: step 1, image 3 of 3
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Alternator Cover Removal: step 2, image 1 of 3 Honda CSC29 Alternator Cover Removal: step 2, image 2 of 3 Honda CSC29 Alternator Cover Removal: step 2, image 3 of 3
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
Chad Lagomarsino
563 Reputation
2 Guides authored
Cal Poly, Team 25-1, Maness Spring 2016 Member of Cal Poly, Team 25-1, Maness Spring 2016
CPSU-MANESS-S16S25G1
4 Members
15 Guides authored
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 18
All Time: 1,825
