Introduction
Alternators like the Honda CSC29 are designed as a stacked assembly. This means that in order to access the internal components of the alternator, external components will have to be moved. Before any part of the alternator can be removed, however, the front cover of the alternator must be removed.
Pull cover off the body of the alternator
Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
