Hitachi CP-X2011N Lens Replacement
    1. Hitachi CP-X2011N Lens Replacement, Motherboard: step 1, image 1 of 3 Hitachi CP-X2011N Lens Replacement, Motherboard: step 1, image 2 of 3 Hitachi CP-X2011N Lens Replacement, Motherboard: step 1, image 3 of 3
      • Orient the projector with the underside facing up and remove all nine 11.5 mm screws with a Phillips #00 screwdriver.
      • On the outlet area on the rear of the device, remove all three 11.5 mm screws with a Phillips #00 screwdriver.
      • Carefully remove the cover using your hands.
      Ask FixBot
    2. Hitachi CP-X2011N Lens Replacement: step 2, image 1 of 3 Hitachi CP-X2011N Lens Replacement: step 2, image 2 of 3 Hitachi CP-X2011N Lens Replacement: step 2, image 3 of 3
      • Remove all four 10.47 mm screws holding the motherboard in place with a Phillips #00 screwdriver.
      Ask FixBot
    3. Hitachi CP-X2011N Lens Replacement: step 3, image 1 of 3 Hitachi CP-X2011N Lens Replacement: step 3, image 2 of 3 Hitachi CP-X2011N Lens Replacement: step 3, image 3 of 3
      • Carefully disconnect all seven ribbon cables and wire connections from the motherboard using tweezers.
      Ask FixBot
    4. Hitachi CP-X2011N Lens Replacement: step 4, image 1 of 1
      • Carefully remove the motherboard from the projector.
      Ask FixBot
    5. Hitachi CP-X2011N Lens Replacement: step 5, image 1 of 3 Hitachi CP-X2011N Lens Replacement: step 5, image 2 of 3 Hitachi CP-X2011N Lens Replacement: step 5, image 3 of 3
      • Remove all jack standoff screws to detach the ports from the cover using a Phillips #00 screwdriver.
      Ask FixBot
    6. Hitachi CP-X2011N Lens Replacement: step 6, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    1. Hitachi CP-X2011N Lens Replacement, Lens: step 7, image 1 of 2 Hitachi CP-X2011N Lens Replacement, Lens: step 7, image 2 of 2
      • Unscrew the two 6 mm screws securing the lens with a a Phillips #00 screwdriver.
      Ask FixBot
    2. Hitachi CP-X2011N Lens Replacement: step 8, image 1 of 1
      • Unscrew the bottom two 6 mm screws securing the projector with a Phillips #00 screwdriver.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uriel Hernandez
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 121
