Hisense Chromebook C11 Battery Replacement
  1. Hisense Chromebook C11 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Battery Replacement: step 2, image 1 of 1
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Battery Replacement: step 3, image 1 of 1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Battery Replacement, Battery: step 4, image 1 of 1
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with the Phillips #000 screwdriver.
  5. Hisense Chromebook C11 Battery Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to unplug the battery.
  6. Hisense Chromebook C11 Battery Replacement: step 6, image 1 of 1
    • Remove the battery.
4 other people completed this guide.
Alexander Burrell
442 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Leahy Fall 2018 Member of USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Members
10 Guides authored
3 Comments
Thank you! Andrew Beiler IBM Research New York
andybeilerny - Reply
Hola mi chome prende pero aparece un recuadro que dice error no esta instalado el chrome os
fidellopez5583 - Reply
Cuanto cuesta la bateria estoy dispuesto a pagar 20 dlls por ella si es nesesario
Marco Antonio Ramírez López - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 25
All Time: 3,440
