Shop the Holiday Gift Guide
HTC Vive Lens Replacement
Views: 10K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
11
All Time:
10,365
Comments: 19
10 comments on steps, 9 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
The HTC Vive's lenses can become scratched, cracked, or dirty with use. This guide will show you how to replace one or both of the HTC Vive lenses.
Tools
    1. HTC Vive Lens Replacement, Release the upper head strap: step 1, image 1 of 2 HTC Vive Lens Replacement, Release the upper head strap: step 1, image 2 of 2
      • Be sure to power down and disconnect your Vive before beginning.
      • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
      Ask FixBot
    2. HTC Vive Lens Replacement, Remove the upper head strap: step 2, image 1 of 2 HTC Vive Lens Replacement, Remove the upper head strap: step 2, image 2 of 2
      • Slide the top part of the head strap through its metal loop on the headset to remove it.
      Ask FixBot
    3. HTC Vive Lens Replacement, Remove the right side of the head strap: step 3, image 1 of 3 HTC Vive Lens Replacement, Remove the right side of the head strap: step 3, image 2 of 3 HTC Vive Lens Replacement, Remove the right side of the head strap: step 3, image 3 of 3
      • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
      • Slide the right side of the head strap through its metal loop to remove it.
      Ask FixBot
    4. HTC Vive Lens Replacement, Remove the left side of the head strap: step 4, image 1 of 3 HTC Vive Lens Replacement, Remove the left side of the head strap: step 4, image 2 of 3 HTC Vive Lens Replacement, Remove the left side of the head strap: step 4, image 3 of 3
      • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
      • Slide the left side of the head strap through its metal loop to remove it.
      Ask FixBot
    5. HTC Vive Lens Replacement, Remove the head strap: step 5, image 1 of 3 HTC Vive Lens Replacement, Remove the head strap: step 5, image 2 of 3 HTC Vive Lens Replacement, Remove the head strap: step 5, image 3 of 3
      • Slide the head strap along the cable, away from the Vive.
      • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
      Ask FixBot
    1. HTC Vive Lens Replacement, Unscrew the head strap mounts: step 6, image 1 of 2 HTC Vive Lens Replacement, Unscrew the head strap mounts: step 6, image 2 of 2
      • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
      • For some devices, a T6 Torx driver may work better.
      • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
      Ask FixBot
    2. HTC Vive Lens Replacement, Remove the head strap mounts: step 7, image 1 of 3 HTC Vive Lens Replacement, Remove the head strap mounts: step 7, image 2 of 3 HTC Vive Lens Replacement, Remove the head strap mounts: step 7, image 3 of 3
      • Remove both head strap mounts.
      Ask FixBot
    3. HTC Vive Lens Replacement, Remove the facerest: step 8, image 1 of 2 HTC Vive Lens Replacement, Remove the facerest: step 8, image 2 of 2
      • Slide the facerest straight away from the headset to remove it.
      Ask FixBot
    1. HTC Vive Lens Replacement, Unscrew the outer shell: step 9, image 1 of 3 HTC Vive Lens Replacement, Unscrew the outer shell: step 9, image 2 of 3 HTC Vive Lens Replacement, Unscrew the outer shell: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the small stickers over the four screws securing the outer shell.
      • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
      Ask FixBot
    2. HTC Vive Lens Replacement, Remove the outer shell: step 10, image 1 of 2 HTC Vive Lens Replacement, Remove the outer shell: step 10, image 2 of 2
      • Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
      Ask FixBot
    3. HTC Vive Lens Replacement: step 11, image 1 of 2 HTC Vive Lens Replacement: step 11, image 2 of 2
      • Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
      • If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
      Ask FixBot
    4. HTC Vive Lens Replacement: step 12, image 1 of 2 HTC Vive Lens Replacement: step 12, image 2 of 2
      • Slide the right side of the outer shell to the right and off of the headset.
      Ask FixBot
    5. HTC Vive Lens Replacement: step 13, image 1 of 2 HTC Vive Lens Replacement: step 13, image 2 of 2
      • Repeat the last three steps for the left side of the outer shell and remove it.
      Ask FixBot
    1. HTC Vive Lens Replacement, Disconnect the sensor array cables: step 14, image 1 of 3 HTC Vive Lens Replacement, Disconnect the sensor array cables: step 14, image 2 of 3 HTC Vive Lens Replacement, Disconnect the sensor array cables: step 14, image 3 of 3
      Buy
      • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
      Ask FixBot
    2. HTC Vive Lens Replacement: step 15, image 1 of 3 HTC Vive Lens Replacement: step 15, image 2 of 3 HTC Vive Lens Replacement: step 15, image 3 of 3
      • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
      • Slide the cable straight out of its socket on the motherboard.
      Ask FixBot
    3. HTC Vive Lens Replacement: step 16, image 1 of 3 HTC Vive Lens Replacement: step 16, image 2 of 3 HTC Vive Lens Replacement: step 16, image 3 of 3
      • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
      Ask FixBot
    4. HTC Vive Lens Replacement: step 17, image 1 of 2 HTC Vive Lens Replacement: step 17, image 2 of 2
      • Use tweezers or a spudger to pry up the camera cable cover and remove it.
      Ask FixBot
    5. HTC Vive Lens Replacement: step 18, image 1 of 2 HTC Vive Lens Replacement: step 18, image 2 of 2
      • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
      Ask FixBot
    6. HTC Vive Lens Replacement, Unscrew the sensor array: step 19, image 1 of 1
      • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
      Ask FixBot
    7. HTC Vive Lens Replacement: step 20, image 1 of 1
      • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
      Ask FixBot
    8. HTC Vive Lens Replacement: step 21, image 1 of 2 HTC Vive Lens Replacement: step 21, image 2 of 2
      Phillips #000 Screwdriver
      $5.49
      Buy
      • You'll need a narrow, long-shaft driver to reach these screws.
      Ask FixBot
    9. HTC Vive Lens Replacement, Remove the sensor array: step 22, image 1 of 2 HTC Vive Lens Replacement, Remove the sensor array: step 22, image 2 of 2
      • Lift the sensor array away from the headset to remove it.
      Ask FixBot
    1. HTC Vive Lens Replacement, Disconnect the motherboard: step 23, image 1 of 3 HTC Vive Lens Replacement, Disconnect the motherboard: step 23, image 2 of 3 HTC Vive Lens Replacement, Disconnect the motherboard: step 23, image 3 of 3
      • Remove the tape covering the interconnect cable socket.
      • Use the point of a spudger to flip up the small locking flap on the cable socket.
      • Slide the interconnect cable straight out of its socket on the motherboard.
      Ask FixBot
    2. HTC Vive Lens Replacement: step 24, image 1 of 3 HTC Vive Lens Replacement: step 24, image 2 of 3 HTC Vive Lens Replacement: step 24, image 3 of 3
      • Remove the tape covering the left OLED cable socket.
      • Slide the left OLED cable straight out of its socket on the motherboard.
      Ask FixBot
    3. HTC Vive Lens Replacement: step 25, image 1 of 3 HTC Vive Lens Replacement: step 25, image 2 of 3 HTC Vive Lens Replacement: step 25, image 3 of 3
      • Remove the tape covering the right OLED cable socket.
      • Slide the right OLED cable straight out of its socket on the motherboard.
      Ask FixBot
    4. HTC Vive Lens Replacement: step 26, image 1 of 2 HTC Vive Lens Replacement: step 26, image 2 of 2
      Buy
      • Use a pair tweezers to slightly twist the interconnect cable and press it down until the tabs on either side of the cable clear the hole in the motherboard.
      • During reassembly, make sure to thread the interconnect cable through its slot in the motherboard.
      Ask FixBot
    5. HTC Vive Lens Replacement, Remove the motherboard: step 27, image 1 of 3 HTC Vive Lens Replacement, Remove the motherboard: step 27, image 2 of 3 HTC Vive Lens Replacement, Remove the motherboard: step 27, image 3 of 3
      • Press the non-port-end of the motherboard toward the top of headset while hinging it away from the midframe to free it from the clips securing that end.
      • Slide the motherboard toward the bottom of the headset, over the clips, to remove it.
      • Take care not to snag any cables during removal.
      Ask FixBot
    1. HTC Vive Lens Replacement, Disconnect the facerest midframe: step 28, image 1 of 3 HTC Vive Lens Replacement, Disconnect the facerest midframe: step 28, image 2 of 3 HTC Vive Lens Replacement, Disconnect the facerest midframe: step 28, image 3 of 3
      Buy
      • Use a pair of tweezers to peel back the plastic covering the eyepiece midframe cable socket.
      • Use the pointed end of a spudger to flip up the plastic locking flap on the socket.
      • Slide the cable straight out of its socket to remove it.
      Ask FixBot
    2. HTC Vive Lens Replacement: step 29, image 1 of 2 HTC Vive Lens Replacement: step 29, image 2 of 2
      • Gently peel the eyepiece midframe cable off of the facerest midframe.
      Ask FixBot
    3. HTC Vive Lens Replacement, Unscrew the facerest midframe: step 30, image 1 of 1
      • Use a PH000 driver to remove the four 3.9 mm screws securing the facerest midframe.
      Ask FixBot
    4. HTC Vive Lens Replacement, Remove the facerest midframe: step 31, image 1 of 2 HTC Vive Lens Replacement, Remove the facerest midframe: step 31, image 2 of 2
      • Lift the facerest midframe off of the eyepiece midframe.
      Ask FixBot
    1. HTC Vive Lens Replacement, Remove the eyepiece gasket: step 32, image 1 of 3 HTC Vive Lens Replacement, Remove the eyepiece gasket: step 32, image 2 of 3 HTC Vive Lens Replacement, Remove the eyepiece gasket: step 32, image 3 of 3
      • Gently lift the eyepiece gasket off of the lens and OLED frames to remove it.
      Ask FixBot
    2. HTC Vive Lens Replacement, Remove the support rod: step 33, image 1 of 3 HTC Vive Lens Replacement, Remove the support rod: step 33, image 2 of 3 HTC Vive Lens Replacement, Remove the support rod: step 33, image 3 of 3
      • Pull the rubber bumpers off of either end of the support rod.
      Ask FixBot
    3. HTC Vive Lens Replacement: step 34, image 1 of 3 HTC Vive Lens Replacement: step 34, image 2 of 3 HTC Vive Lens Replacement: step 34, image 3 of 3
      • Slide the support rod out of its brackets on the lens and OLED frames.
      Ask FixBot
    4. HTC Vive Lens Replacement, Remove the focus rod: step 35, image 1 of 1
      • Use a PH000 driver to remove the eight 3.1 mm screws securing the focus rod brackets.
      Ask FixBot
    5. HTC Vive Lens Replacement: step 36, image 1 of 1
      • Remove the focus rod and its brackets.
      Ask FixBot
    6. HTC Vive Lens Replacement, Unscrew the OLED covers: step 37, image 1 of 1
      • Use a PH000 driver to remove the eight 2.4 mm screws securing the OLED covers.
      Ask FixBot
    7. HTC Vive Lens Replacement, Remove the OLED covers: step 38, image 1 of 2 HTC Vive Lens Replacement, Remove the OLED covers: step 38, image 2 of 2
      • Use the flat end of a spudger push up one edge of the OLED cover and start unclipping that edge.
      Ask FixBot
    8. HTC Vive Lens Replacement: step 39, image 1 of 2 HTC Vive Lens Replacement: step 39, image 2 of 2
      • Slide the spudger under the clip along that edge to free the rest of the edge.
      Ask FixBot
    9. HTC Vive Lens Replacement: step 40, image 1 of 3 HTC Vive Lens Replacement: step 40, image 2 of 3 HTC Vive Lens Replacement: step 40, image 3 of 3
      • Slide the spudger around the remaining edges of the OLED cover to unclip those edges.
      Ask FixBot
    10. HTC Vive Lens Replacement: step 41, image 1 of 2 HTC Vive Lens Replacement: step 41, image 2 of 2
      • Remove the OLED cover.
      • Repeat the last three steps to remove the other OLED cover.
      • During reassembly, remember to thread the OLED cables through their slots in the OLED cover.
      Ask FixBot
    11. HTC Vive Lens Replacement, Remove the OLED displays: step 42, image 1 of 1
      • Very carefully lift the OLED display by its edges out of its frame.
      • If you are reusing the OLED displays, be very careful to avoid touching the front of the displays or bending or cracking the displays.
      • Repeat this process for the other OLED display.
      Ask FixBot
    12. HTC Vive Lens Replacement, Remove the lenses: step 43, image 1 of 1
      • Apply an iOpener to the lens to soften the adhesive securing it to the frame.
      Ask FixBot
    13. HTC Vive Lens Replacement: step 44, image 1 of 2 HTC Vive Lens Replacement: step 44, image 2 of 2
      • Use an opening tool to pry up the flat edge of the lens.
      • If it's difficult to pry up, apply the iOpener for another 30 seconds to further soften the adhesive.
      Ask FixBot
    14. HTC Vive Lens Replacement, Remove the lens: step 45, image 1 of 1
      • Remove the lens.
      • Repeat the last two steps to remove the other lens.
      • Only the lens and OLED frames remain.
      • During reassembly, make sure the convex side of the lens is facing away from the frame.
      Ask FixBot
    1. HTC Vive Lens Replacement, OLED Screen: step 46, image 1 of 1
      • The screws are very close to the screen. Applying too much pressure to the screws can stress or crack the screen. Be careful when unscrewing and screwing around the screen.
      • Remove the four 2mm #00 Philips head screws holding the screen in place from the eyepiece assembly.
      Ask FixBot
    2. HTC Vive Lens Replacement: step 47, image 1 of 3 HTC Vive Lens Replacement: step 47, image 2 of 3 HTC Vive Lens Replacement: step 47, image 3 of 3
      • Use a plastic opening tool to gently pry around the seam between the eyepiece housing and the screen.
      • Gently pull the screen cover away from the eyepiece housing, threading the ribbon cable through the hole.
      Ask FixBot
    3. HTC Vive Lens Replacement: step 48, image 1 of 2 HTC Vive Lens Replacement: step 48, image 2 of 2
      • Remove the screen from the eyepiece housing by pulling the two pieces away from each other.
      Ask FixBot
    1. HTC Vive Lens Replacement, Lens: step 49, image 1 of 2 HTC Vive Lens Replacement, Lens: step 49, image 2 of 2
      • Hold your hand in front of the lens and be ready to catch the lens during its removal.
      • From the inside of the black plastic housing, push gently around the edges of the lens to remove it.
      • Glue holds the lens in place; pushing around the edges will gradually loosen and break the bond. After breaking the bond, the lens will fall forward.
      Ask FixBot
6 other people completed this guide.
Author
with
Caleb Watts
2,439 Reputation
11 Guides authored
Cal Poly, Team S18-G1, Forte Fall 2017 Member of Cal Poly, Team S18-G1, Forte Fall 2017
CPSU-FORTE-F17S18G1
5 Members
132 Guides authored
9 Guide Comments
Or… you can simply use an exacto knife and pry the lenses out without taking the entire HMD apart!
You can insert a scalpel type knife between the lens and the housing and work your way around.
techy76 - Reply Share
I’ve got to agree . This is the absolute worst way to do what’s essentially a simple operation. So many ways this could go wrong for the user if they’re not careful.
This reeks of click bait re-purposing of the tear-down coverage.
Ian Kennedy - Reply Share
This has to be the most overly complicated approach for a VERY simple fix. Takes about 5 seconds to pop out the lenses by carefully prying at the flat edge with a butter knife, exacto knife, etc.
Brian Lovett - Reply Share
Agreed! what rubbish…
Lionel Van Niekerk - Reply Share
We are showing you the most technical and professional way to take out the lens. Remember this is just a guide. You can use whichever way you most comfortable to take apart your HTC.
Huy Duong - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 10,365
