Installing HTC SMT 6175 Keyboard
  1. Installing HTC SMT 6175 Keyboard, Back Case: step 1, image 1 of 1
    • First, flip the phone over so that the back is facing upwards.
  2. Installing HTC SMT 6175 Keyboard: step 2, image 1 of 2 Installing HTC SMT 6175 Keyboard: step 2, image 2 of 2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. Installing HTC SMT 6175 Keyboard, Battery: step 3, image 1 of 2 Installing HTC SMT 6175 Keyboard, Battery: step 3, image 2 of 2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. Installing HTC SMT 6175 Keyboard, Keyboard: step 4, image 1 of 2 Installing HTC SMT 6175 Keyboard, Keyboard: step 4, image 2 of 2
    • To remove the back casing inside the phone, unscrew the 6 screws that are around the perimeter of the phone.
  5. Installing HTC SMT 6175 Keyboard: step 5, image 1 of 2 Installing HTC SMT 6175 Keyboard: step 5, image 2 of 2
    • Carefully pull off back casing.
    • Warning: This can be difficult, but just start pulling the back out from the front shell. As it starts to lift up, continue moving around the phone until the whole back becomes free.
  6. Installing HTC SMT 6175 Keyboard: step 6, image 1 of 2 Installing HTC SMT 6175 Keyboard: step 6, image 2 of 2
    • Next unscrew the top screw.
    • Warning: Be CAREFUL because the LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable.
  7. Installing HTC SMT 6175 Keyboard, QWERTY Keyboard: step 7, image 1 of 3 Installing HTC SMT 6175 Keyboard, QWERTY Keyboard: step 7, image 2 of 3 Installing HTC SMT 6175 Keyboard, QWERTY Keyboard: step 7, image 3 of 3
    • Pull the plastic keyboard away from the front case.
  8. Installing HTC SMT 6175 Keyboard, Navigation Keys: step 8, image 1 of 3 Installing HTC SMT 6175 Keyboard, Navigation Keys: step 8, image 2 of 3 Installing HTC SMT 6175 Keyboard, Navigation Keys: step 8, image 3 of 3
    • To remove the navigation keys on the front of the phone, unscrew the four screws circled using a Philips screwdriver.
    • Remove the navigation keys from the front of the phone. They should pop out as a unit.
Luke Plewa
116 Reputation
4 Guides authored
Cal Poly, Team 25-29, Garner Spring 2011 Member of Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,678
