Introduction
Replace your HTC Radar 4G Battery.
Remove the 4 silver T5 Torx screws from the motherboard protector.
Gently push on the motherboard until the display starts to come out of its frame.
Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
Tool used on this step:iFixit Opening Picks (Set of 6)$4.95
Use a fingernail or an opening pick to lift the battery out of its slot.
Once it is at about a 30-degree angle, pull up on the battery to disconnect it.
To reassemble your device, follow these instructions in reverse order. Calibrate your new battery for optimal performance.Take your e-waste to an R2 or e-Stewards certified recycler.
