HTC One X Plus Screen Replacement
  1. HTC One X Plus Screen Replacement, Screen: step 1, image 1 of 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Screen Replacement: step 2, image 1 of 3 HTC One X Plus Screen Replacement: step 2, image 2 of 3 HTC One X Plus Screen Replacement: step 2, image 3 of 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Screen Replacement: step 3, image 1 of 3 HTC One X Plus Screen Replacement: step 3, image 2 of 3 HTC One X Plus Screen Replacement: step 3, image 3 of 3
    • Remove the five 2.4mm screws using a Philips head screw driver and then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Screen Replacement: step 4, image 1 of 3 HTC One X Plus Screen Replacement: step 4, image 2 of 3 HTC One X Plus Screen Replacement: step 4, image 3 of 3
    • Use the J000 Philips screw driver head to remove the screws.
    • Two 3.4mm Philips head screws
    • Remove the PCB board and antenna.
  5. HTC One X Plus Screen Replacement: step 5, image 1 of 2 HTC One X Plus Screen Replacement: step 5, image 2 of 2
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Screen Replacement: step 6, image 1 of 3 HTC One X Plus Screen Replacement: step 6, image 2 of 3 HTC One X Plus Screen Replacement: step 6, image 3 of 3
    • Disconnect the battery from the logic board.
    • Six pin connector
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Screen Replacement: step 7, image 1 of 1
    • You must now disconnect the screen which are glued together.
    • Using a plastic spudger gently disconnect the screen from the digitizer.
    • You may have to use hot air to loosen the screen.
Jason Melo
483 Reputation
4 Guides authored
USF Tampa, Team 3-3, Eyestone Fall 2015 Member of USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,854
