Introduction
You may need to replace your screen if it is broken or cracked.
Power off your device.
Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
Using plastic opening tools, pry open the bottom of the device first.
You will hear clicking sounds as the sides of the device detach from the screen.
Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
Remove the five 2.4mm screws using a Philips head screw driver and then remove the plastic cover.
Use the J000 Philips screw driver head to remove the screws.
Two 3.4mm Philips head screws
Remove the PCB board and antenna.
Use tweezers to disconnect the power button flex cable.
Disconnect the touch screen flex cable
Disconnect the battery from the logic board.
Six pin connector
Remove the battery by pulling upwards.
You must now disconnect the screen which are glued together.
Using a plastic spudger gently disconnect the screen from the digitizer.
