Introduction
Replacing the battery of this phone is not an easy procedure. We will guide you on how to disassemble the phone and replace the battery.
The video manual is for LCD Display & Touch screen replacing, but you can follow it until the moment when we separate the main board & battery from the LCD frame.
Video Overview
Switch the phone off.
Remove the SIM tray.
It's helpful to use heat to loosen the adhesive, making removal much easier.
Remove the seven Philips #0 screws at the top of the panel:
Two 2.05 mm screws
Three 2.44 mm screws
Two 3.35 mm screws
Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
Disconnect one by one:
the Touchscreen flex cable
the Volume buttons & Mic flex cable
the Dock connector flex cable
Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
Now you can separate the Dock flex cable.
Carefully pry the EMI shield up at the top of the phone and toward the battery.
Carefully peel the copper tape off of the battery and save it to transfer to the new battery.
Lift the motherboard slightly to disconnect two flex cables:
the LCD Display flex cable
the Navigation buttons flex cable
Disconnect the Power On button flex cable at the upper side of the phone
Now the mainboard and the battery are free.
Disconnect the battery and you are ready to install the new one.
