HTC One X Battery Replacement
Video Overview
  1. HTC One X Battery Replacement, Battery: step 1, image 1 of 3 HTC One X Battery Replacement, Battery: step 1, image 2 of 3 HTC One X Battery Replacement, Battery: step 1, image 3 of 3
    • Switch the phone off.
    • Remove the SIM tray.
    • The back cover is stuck to the phone with adhesive tape.
    • It's helpful to use heat to loosen the adhesive, making removal much easier.
  2. HTC One X Battery Replacement: step 2, image 1 of 3 HTC One X Battery Replacement: step 2, image 2 of 3 HTC One X Battery Replacement: step 2, image 3 of 3
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X Battery Replacement: step 3, image 1 of 2 HTC One X Battery Replacement: step 3, image 2 of 2
    • Remove the display assembly from the body of the phone.
  4. HTC One X Battery Replacement: step 4, image 1 of 2 HTC One X Battery Replacement: step 4, image 2 of 2
    • Remove the seven Philips #0 screws at the top of the panel:
    • Two 2.05 mm screws
    • Three 2.44 mm screws
    • Two 3.35 mm screws
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
  5. HTC One X Battery Replacement: step 5, image 1 of 3 HTC One X Battery Replacement: step 5, image 2 of 3 HTC One X Battery Replacement: step 5, image 3 of 3
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  6. HTC One X Battery Replacement: step 6, image 1 of 2 HTC One X Battery Replacement: step 6, image 2 of 2
    • A piece of copper tape covers the battery and an EMI shield on the motherboard.
    • Carefully pry the EMI shield up at the top of the phone and toward the battery.
    • Carefully peel the copper tape off of the battery and save it to transfer to the new battery.
  7. HTC One X Battery Replacement: step 7, image 1 of 3 HTC One X Battery Replacement: step 7, image 2 of 3 HTC One X Battery Replacement: step 7, image 3 of 3
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery and you are ready to install the new one.
  8. HTC One X Battery Replacement: step 8, image 1 of 2 HTC One X Battery Replacement: step 8, image 2 of 2
    • Battery pack - 3.7 VDC, 1800MAh,
    • Did you do it successfully.
ZFix
191,507 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,487 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 46
All Time: 46,554
