HTC Desire 826 Front Camera Replacement
    1. HTC Desire 826 Front Camera Replacement, Battery: step 1, image 1 of 3 HTC Desire 826 Front Camera Replacement, Battery: step 1, image 2 of 3 HTC Desire 826 Front Camera Replacement, Battery: step 1, image 3 of 3
      • Find a seam in the back of the device.
      • Insert the plastic spudger into the seam and pry off the back panel.
      • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
      Ask FixBot
    2. HTC Desire 826 Front Camera Replacement: step 2, image 1 of 3 HTC Desire 826 Front Camera Replacement: step 2, image 2 of 3 HTC Desire 826 Front Camera Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
      • Remove the metal bracket with the tweezers.
      Ask FixBot
    3. HTC Desire 826 Front Camera Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the motherboard with the tweezers.
      Ask FixBot
    4. HTC Desire 826 Front Camera Replacement: step 4, image 1 of 2 HTC Desire 826 Front Camera Replacement: step 4, image 2 of 2
      • Lift the battery with a plastic spudger and remove it from the device.
      Ask FixBot
    1. HTC Desire 826 Front Camera Replacement, Front Camera: step 5, image 1 of 3 HTC Desire 826 Front Camera Replacement, Front Camera: step 5, image 2 of 3 HTC Desire 826 Front Camera Replacement, Front Camera: step 5, image 3 of 3
      • Use the T5 screwdriver to remove the three 4.0 mm screws as shown.
      • Once the screws are removed, pry up the top plastic panel using the black nylon spudger.
      Ask FixBot
    2. HTC Desire 826 Front Camera Replacement: step 6, image 1 of 2 HTC Desire 826 Front Camera Replacement: step 6, image 2 of 2
      Buy
      • Use the tweezers to detach the cameras wire from the top motherboard
      • Then use the tweezers to remove the camera
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 48
All Time: 498
