Introduction
If the troubleshooting procedures and all of the previous steps do not work it may be time to change the motherboard ground wire.
Remove the screw caps using a metal spudger.
Remove the four 6 mm screws using a Phillips #0 screwdriver.
Insert a plastic opening tool into the case seam and slide it along the edges.
Lift and remove the back panel from the device.
