HP eStation Zeen Ground Wire Replacement
  1. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: step 1, image 1 of 3 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: step 1, image 2 of 3 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: step 1, image 3 of 3
    • Remove the screw caps using a metal spudger.
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
  2. HP eStation Zeen Ground Wire Replacement: step 2, image 1 of 3 HP eStation Zeen Ground Wire Replacement: step 2, image 2 of 3 HP eStation Zeen Ground Wire Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool into the case seam and slide it along the edges.
    • Lift and remove the back panel from the device.
  3. HP eStation Zeen Ground Wire Replacement: step 3, image 1 of 1
    • Carefully disconnect the battery clip using small plastic spudger.
    • The clip is extremely fragile.
  4. HP eStation Zeen Ground Wire Replacement: step 4, image 1 of 1
    • Use tweezers to disconnect the ground wire from motherboard terminal.
  5. HP eStation Zeen Ground Wire Replacement: step 5, image 1 of 1
    • Remove ground wire using solder iron.
    • Heating the motherboard may cause damage.
dalton hale
503 Reputation
4 Guides authored
USF Tampa, Team 16-4, Eyestone Fall 2016 Member of USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Members
10 Guides authored
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 11
All Time: 363
