Introduction
Use this guide to replace the back cover of your HP Stream x360 11 -p015wm.
The back cover is important for protecting the internal components. A cracked or damage back cover can allow dust and moisture to damage hardware.
If the back cover is being removed to change the battery, click this link. While the back cover is removed, consider using these methods to clean internal hardware.
Before beginning, ensure the device is completely off and disconnect any external power source.
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Tool used on this step:iFixit Opening Tool$1.99
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
