HP Stream 8 Battery Replacement
  1. HP Stream 8 Battery Replacement, Midframe: step 1, image 1 of 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Battery Replacement: step 2, image 1 of 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Battery Replacement: step 3, image 1 of 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Battery Replacement: step 4, image 1 of 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Battery Replacement, Front-Facing Camera: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Battery Replacement: step 6, image 1 of 1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Battery Replacement, Rear-Facing Camera: step 7, image 1 of 1
    Buy
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Battery Replacement: step 8, image 1 of 1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Battery Replacement, Motherboard: step 9, image 1 of 1
    Buy
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Battery Replacement: step 10, image 1 of 1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Battery Replacement: step 11, image 1 of 1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Battery Replacement: step 12, image 1 of 1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Battery Replacement: step 13, image 1 of 1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Battery Replacement: step 14, image 1 of 1
    • Remove the motherboard from the device.
  15. HP Stream 8 Battery Replacement, Battery: step 15, image 1 of 1
    • Remove the 6 PH00 Phillips screws.
  16. HP Stream 8 Battery Replacement: step 16, image 1 of 1
    • The battery can now be removed from the device.
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 4,754
