Slide your finger around the rest of the back cover, lifting it completely off of the device.
Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
Carefully remove the battery connector from the system board using the tweezers.
Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
