Introduction
Sometimes the keyboard of an HP Stream 11-d010nr will start to behave sub optimally, such as unresponsive or sticky keys. This guide will show you how to replace it.
Flip the device over.
Using a metal spudger, pry off the two elliptical rubber inserts (one in each corner).
Using a metal spudger, pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
Carefully disconnect the three ribbon cables using two fingers.
