HP Stream 11-d010nr Keyboard Replacement
  1. HP Stream 11-d010nr Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP Stream 11-d010nr Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Flip the device over.
    • Using a metal spudger, pry off the two elliptical rubber inserts (one in each corner).
    • Using a metal spudger, pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Keyboard Replacement: step 2, image 1 of 1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Keyboard Replacement: step 3, image 1 of 2 HP Stream 11-d010nr Keyboard Replacement: step 3, image 2 of 2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Keyboard Replacement: step 4, image 1 of 1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Keyboard Replacement: step 5, image 1 of 3 HP Stream 11-d010nr Keyboard Replacement: step 5, image 2 of 3 HP Stream 11-d010nr Keyboard Replacement: step 5, image 3 of 3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables using two fingers.
  6. HP Stream 11-d010nr Keyboard Replacement: step 6, image 1 of 1
    • Lift the keyboard out of the laptop to remove it from the device.
Josh Corrigan
341 Reputation
2 Guides authored
Cal Poly, Team S1-G3, White Winter 2019 Member of Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Members
11 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 8
All Time: 834
