HP ProBook 640 G4 RAM Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
65
All Time:
358
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The HP Probook 640 G4 is a business class 14 inch laptop that is designed for durability. This guide will walk you through how to safely replace the RAM. A failing RAM can cause random freezes and "out of memory" errors.
Before you start be sure to power the laptop off completely, unplug the AC adapter, and remove all external devices. Work on a clean flat surface. Make sure you have all of the right tools and parts available.
If your Probook is slow with many browser tabs, shows "low memory" warnings, or crashes often, replacing the RAM often helps. After replacement, be sure to run Windows Memory Diagnostic to verify that your replacements are recognized.
Tools
    1. HP ProBook 640 G4 RAM Replacement, Lower Case: step 1, image 1 of 2 HP ProBook 640 G4 RAM Replacement, Lower Case: step 1, image 2 of 2
      • Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
      • Captive screws cannot be fully removed.
      Ask FixBot
    2. HP ProBook 640 G4 RAM Replacement: step 2, image 1 of 2 HP ProBook 640 G4 RAM Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis, and twist it to create a gap.
      • Insert an opening tool into the gap.
      • Use the opening tool to pry around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 640 G4 RAM Replacement, Battery: step 3, image 1 of 3 HP ProBook 640 G4 RAM Replacement, Battery: step 3, image 2 of 3 HP ProBook 640 G4 RAM Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
      • Captive screws are not fully removable—they only loosen.
      • Slide and lift the battery out.
      Ask FixBot
    1. HP ProBook 640 G4 RAM Replacement, RAM: step 4, image 1 of 3 HP ProBook 640 G4 RAM Replacement, RAM: step 4, image 2 of 3 HP ProBook 640 G4 RAM Replacement, RAM: step 4, image 3 of 3
      • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Repeat for the other RAM module.
      • Remove each of the two RAM modules.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Timothy Zibrida
523 Reputation
5 Guides authored
UMass Dartmouth, Team 1-5, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-5, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 65
All Time: 358
