HP ProBook 640 G4 Battery Replacement
    1. HP ProBook 640 G4 Battery Replacement, Lower Case: step 1, image 1 of 2 HP ProBook 640 G4 Battery Replacement, Lower Case: step 1, image 2 of 2
      • Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
      • Captive screws cannot be fully removed.
      Ask FixBot
    2. HP ProBook 640 G4 Battery Replacement: step 2, image 1 of 2 HP ProBook 640 G4 Battery Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis, and twist it to create a gap.
      • Insert an opening tool into the gap.
      • Use the opening tool to pry around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 640 G4 Battery Replacement, Battery: step 3, image 1 of 3 HP ProBook 640 G4 Battery Replacement, Battery: step 3, image 2 of 3 HP ProBook 640 G4 Battery Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
      • Captive screws are not fully removable—they only loosen.
      • Slide and lift the battery out.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Timothy Zibrida
523 Reputation
5 Guides authored
UMass Dartmouth, Team 1-5, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-5, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G5
3 Members
82 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 71
All Time: 435
