HP ProBook 640 G3 Screen Replacement
    1. HP ProBook 640 G3 Screen Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 640 G3 Screen Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 640 G3 Screen Replacement, Lower Case: step 1, image 3 of 3
      • Before beginning, power the device down and disconnect all peripheries.
      • Remove the eight 6 mm-long Phillips screws securing the lower case.
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter of the device until the lower case releases.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 640 G3 Screen Replacement, Battery: step 2, image 1 of 3 HP ProBook 640 G3 Screen Replacement, Battery: step 2, image 2 of 3 HP ProBook 640 G3 Screen Replacement, Battery: step 2, image 3 of 3
      • Use a Phillips screwdriver to loosen the seven 6 mm-long captive screws securing the battery.
      • These screws are built into the edges of the battery, so they only need to be loosened in order for the battery to be taken out.
      Ask FixBot
    2. HP ProBook 640 G3 Screen Replacement: step 3, image 1 of 3 HP ProBook 640 G3 Screen Replacement: step 3, image 2 of 3 HP ProBook 640 G3 Screen Replacement: step 3, image 3 of 3
      • Remove the battery.
      • If the battery will not come out, you may need to loosen the screws more; refer back to step 2.
      Ask FixBot
    1. HP ProBook 640 G3 Screen Replacement, RAM: step 4, image 1 of 3 HP ProBook 640 G3 Screen Replacement, RAM: step 4, image 2 of 3 HP ProBook 640 G3 Screen Replacement, RAM: step 4, image 3 of 3
      • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Gently remove the memory from its housing by pulling it out and up.
      • Retention arms are thin and fragile, be careful when unhooking them.
      Ask FixBot
    2. HP ProBook 640 G3 Screen Replacement: step 5, image 1 of 3 HP ProBook 640 G3 Screen Replacement: step 5, image 2 of 3 HP ProBook 640 G3 Screen Replacement: step 5, image 3 of 3
      • Repeat the previous step for the second memory card.
      • During reassembly, the memory card can be slid back into its slot and gently pushed down. The retention arms will then secure around the card on their own and don't need to be pried open.
      Ask FixBot
    1. HP ProBook 640 G3 Screen Replacement, Wi-Fi Card: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the two 6 mm-long screws on the metal piece holding down the Wi-Fi card. One screw will be on top, and the other will be just next to the wires holding it in.
      • Carefully remove the little metal piece from where it was resting.
      • The metal piece is small and non-magnetic. Leave in clear line of sight to avoid losing it.
      Ask FixBot
    2. HP ProBook 640 G3 Screen Replacement: step 7, image 1 of 1
      • The only thing holding the Wi-Fi card will be two small wires. These can easily be taken off by the use of your hands or helpful tweezers.
      • Gently remove the card by pulling it out of its slot.
      Ask FixBot
    1. HP ProBook 640 G3 Screen Replacement, Fan and Heat Sink: step 8, image 1 of 1
      • There are 22 total screws that hold down the base of the laptop. These vary between flat head Phillips and Torx head screws.
      • From here we've labeled the Torx screws as squares and the Phillips screws as circles. In case of any contradictions between your device's labels or current screws and this guide, we recommend going by the device's labels.
      • Remove the 2 M2.0x6
      • Remove the 8 M2.5x6 screws
      • Remove the 6 M2.0x3
      • The two screws here are M2.5x3 and M2.0x3. In the case of our device, these screws were like the battery screws, as in they did not need to be removed to continue. This could be the case with your device but if not, feel free to remove them.
      • These screws will be smaller than M2.0x3, consider sizes such as M2.0x2, M2.0x1.5, M2.0x1 and possibly smaller.
      • We highly recommend the usage of a magnetic strip to keep track of the screws being removed and replaced to avoid confusion.
      Ask FixBot
    2. HP ProBook 640 G3 Screen Replacement: step 9, image 1 of 3 HP ProBook 640 G3 Screen Replacement: step 9, image 2 of 3 HP ProBook 640 G3 Screen Replacement: step 9, image 3 of 3
      • Pull the DVD disk out.
      Ask FixBot
    3. HP ProBook 640 G3 Screen Replacement: step 10, image 1 of 1
      • Locate the row of four screws along the edge of the optical drive bay (the empty slot where the DVD drive was).
      • Remove the two screws on the left (closer to the hinge/connectors). These are typically M2.0 x 3mm.
      • Remove the two screws on the right (closer to the front corner). These are typically smaller, M2.0 x 1.5mm.
      • As mentioned in prior steps, the plastic chassis is often labeled next to the screw holes with the size (e.g., "M2.0x3" or "M2.0x1.5") to help you identify which screw goes where during reassembly.
      Ask FixBot
    4. HP ProBook 640 G3 Screen Replacement: step 11, image 1 of 3 HP ProBook 640 G3 Screen Replacement: step 11, image 2 of 3 HP ProBook 640 G3 Screen Replacement: step 11, image 3 of 3
      • Insert your opening pick into the seam between the top palm rest assembly (where the keyboard is) and the bottom case.
      • Slide the pick along the front and side edges to release the internal plastic clips securing the top cover.
      • Once the clips are disengaged, gently lift the keyboard compartment away to reveal the motherboard components underneath.
      Ask FixBot
    5. HP ProBook 640 G3 Screen Replacement: step 12, image 1 of 3 HP ProBook 640 G3 Screen Replacement: step 12, image 2 of 3 HP ProBook 640 G3 Screen Replacement: step 12, image 3 of 3
      • This step is not required for replacing the screen
      • Use the Phillips head screwdriver to loosen the M2.5x1.5 screws.
      • Use the Phillips head screwdriver to loosen the M2.5x3 screw.
      • Loosen the M2.5x3.5 screws with the Phillips head screwdriver
      • Carefully detach the cooling fan and its connection from the device.
      • Just like our battery, the screws are attached to the cooling fan and its connector. The batteries connected to the attached component are done so with springs.
      Ask FixBot
    1. HP ProBook 640 G3 Screen Replacement, Screen: step 13, image 1 of 2 HP ProBook 640 G3 Screen Replacement, Screen: step 13, image 2 of 2
      • Locate the metal hinge brackets on the top left and top right corners of the laptop base.
      • Remove the 4 M2.5x3 screws that secure the hinges on the main chassis
      • Remove the M2.5x3.5 screws that secure the hinges
      • Remove the big M3.0x3 screw that secures the hinge
      • To make sure the hinges are fully loosened and removed, you can gently lift the screen to see if they move out with it. If not, check back for screws
      • Do not remove the screen until proceeding to the next step.
      Ask FixBot
    2. HP ProBook 640 G3 Screen Replacement: step 14, image 1 of 3 HP ProBook 640 G3 Screen Replacement: step 14, image 2 of 3 HP ProBook 640 G3 Screen Replacement: step 14, image 3 of 3
      • Before separating the screen, you must disconnect the cables connecting the display to the motherboard.
      • Carefully disconnect the display data cable (usually a flat connector) and any antenna wires located near the hinges.
      • Gently guide these wires out of their plastic routing channels/clips so they are hanging free. This ensures they don't get snagged or torn when you lift the screen assembly away from the base.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andrew Patnaude
265 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-7, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G7
3 Members
66 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 52
All Time: 304
