HP ProBook 455 G7 RAM Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
33
Past 30 Days:
92
All Time:
382
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide explains how to replace or upgrade the RAM in the HP ProBook 455 G7 (Model: 7JN02AV). The RAM (Random Access Memory) is responsible for short-term data processing and directly affects multitasking speed and system responsiveness.
Common symptoms of failing or insufficient RAM include freezing, programs not loading, blue screens, and overall slow performance. For more detail, see the “Performance Issues” section of the Troubleshooting Page.
Make sure the laptop is fully powered down and unplugged.
Handle RAM modules only by their edges and avoid touching the gold contacts.
If you’re upgrading, HP recommends matching the RAM’s speed, type, and voltage to your existing module.
Tools
    1. HP ProBook 455 G7 RAM Replacement, Lower Case: step 1, image 1 of 1
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      Ask FixBot
    2. HP ProBook 455 G7 RAM Replacement: step 2, image 1 of 3 HP ProBook 455 G7 RAM Replacement: step 2, image 2 of 3 HP ProBook 455 G7 RAM Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      Ask FixBot
    1. HP ProBook 455 G7 RAM Replacement, Battery: step 3, image 1 of 3 HP ProBook 455 G7 RAM Replacement, Battery: step 3, image 2 of 3 HP ProBook 455 G7 RAM Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      Ask FixBot
    1. HP ProBook 455 G7 RAM Replacement, RAM: step 4, image 1 of 1
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      Ask FixBot
    2. HP ProBook 455 G7 RAM Replacement: step 5, image 1 of 1
      • The RAM stick should pop up at an angle.
      Ask FixBot
    3. HP ProBook 455 G7 RAM Replacement: step 6, image 1 of 1
      • Carefully pull the module directly out of its socket.
      • Align the notch on the new RAM module with the slot in the connector.
      • Slide the module in at an angle, then press down until it clicks into place.
      • The HP ProBook 455 G7 typically supports DDR4 SO-DIMM RAM up to 32 GB (2 × 16 GB). Make sure both sticks are properly seated before reassembling.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
Andiany Reynoso
259 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 92
All Time: 382
