HP Pavilion 15-eg0021nr RAM Module Replacement
    1. HP Pavilion 15-eg0021nr RAM Module Replacement, Lower Case: step 1, image 1 of 1
      • Completely power off and unplug the charger and any peripheries before beginning.
      • Close the display and flip the laptop upside-down.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the feet, lightly heat them with a hair dryer and take care not to warp or tear them as your remove them.
      Ask FixBot
    2. HP Pavilion 15-eg0021nr RAM Module Replacement: step 2, image 1 of 1
      • Remove the following screws securing the lower case with a Phillips #1 screwdriver:
      • Four 6 mm-long
      • Two 5.5 mm-long
      Ask FixBot
    3. HP Pavilion 15-eg0021nr RAM Module Replacement: step 3, image 1 of 3 HP Pavilion 15-eg0021nr RAM Module Replacement: step 3, image 2 of 3 HP Pavilion 15-eg0021nr RAM Module Replacement: step 3, image 3 of 3
      • Insert an opening pick into the seam between the lower case and chassis,
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP Pavilion 15-eg0021nr RAM Module Replacement, RAM Module: step 4, image 1 of 3 HP Pavilion 15-eg0021nr RAM Module Replacement, RAM Module: step 4, image 2 of 3 HP Pavilion 15-eg0021nr RAM Module Replacement, RAM Module: step 4, image 3 of 3
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Pushing too forcefully on the clips may cause them to bend, rending them incapable or properly securing the RAM stick.
      • Remove the RAM module.
      Ask FixBot
    2. HP Pavilion 15-eg0021nr RAM Module Replacement: step 5, image 1 of 3 HP Pavilion 15-eg0021nr RAM Module Replacement: step 5, image 2 of 3 HP Pavilion 15-eg0021nr RAM Module Replacement: step 5, image 3 of 3
      • To insert the new one slide it in.
      • Note: The new RAM stick will now be at an angle. Not flush with the clips. It will look like the second picture.
      • Press down on the RAM stick and you will hear a click. This ensures that the metal clips have reclipped onto the new RAM stick.
      • Reminder: The last picture shows how the RAM stick looks after it has been fully inserted.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 86
All Time: 195
