HP Pavilion 15-ab165us Motherboard Replacement
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: step 1, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: step 1, image 2 of 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: step 2, image 1 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 2, image 2 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 2, image 3 of 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: step 3, image 1 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 3, image 2 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 3, image 3 of 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: step 4, image 1 of 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: step 5, image 1 of 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: step 6, image 1 of 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: step 7, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 7, image 2 of 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: step 8, image 1 of 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: step 10, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 10, image 2 of 2
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: step 11, image 1 of 1
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: step 12, image 1 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 12, image 2 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 12, image 3 of 3
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: step 13, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 13, image 2 of 2
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: step 14, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 14, image 2 of 2
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: step 15, image 1 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 15, image 2 of 3 HP Pavilion 15-ab165us Motherboard Replacement: step 15, image 3 of 3
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: step 16, image 1 of 1
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: step 17, image 1 of 1
    • Remove the 4mm screws holding the motherboard in place with a Philips #1 screwdriver.
  18. HP Pavilion 15-ab165us Motherboard Replacement: step 18, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 18, image 2 of 2
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: step 19, image 1 of 1
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: step 20, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 20, image 2 of 2
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: step 21, image 1 of 2 HP Pavilion 15-ab165us Motherboard Replacement: step 21, image 2 of 2
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
Dillon Hubble
653 Reputation
3 Guides authored
UW Tacoma, Team S1-G2, Rose Fall 2017 Member of UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,497
