Introduction
You will be removing a small plastic cover to get to your device's RAM, then with a couple short steps you will be able to remove it.
Apply moderate pressure to the tab and slide it to the right.
While the tab is on the right, you should be able to gently slide your battery out of your device.
Place your fingers on little metals tabs on both sides of the RAM casing.
Push the tabs towards the sides. This should cause the RAM to pop up.
