HP G60T-600 CTO RAM Replacement
  1. HP G60T-600 CTO RAM Replacement, Battery: step 1, image 1 of 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO RAM Replacement: step 2, image 1 of 2 HP G60T-600 CTO RAM Replacement: step 2, image 2 of 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO RAM Replacement: step 3, image 1 of 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO RAM Replacement, RAM: step 4, image 1 of 1
    • Turn your device over and orient it so the battery is facing you.
  5. HP G60T-600 CTO RAM Replacement: step 5, image 1 of 3 HP G60T-600 CTO RAM Replacement: step 5, image 2 of 3 HP G60T-600 CTO RAM Replacement: step 5, image 3 of 3
    • Unscrew the following 5mm screws using a Phillip's head #0 screwdriver.
    • Remove the cover.
  6. HP G60T-600 CTO RAM Replacement: step 6, image 1 of 3 HP G60T-600 CTO RAM Replacement: step 6, image 2 of 3 HP G60T-600 CTO RAM Replacement: step 6, image 3 of 3
    • Place your fingers on little metals tabs on both sides of the RAM casing.
    • Push the tabs towards the sides. This should cause the RAM to pop up.
  7. HP G60T-600 CTO RAM Replacement: step 7, image 1 of 1
    • Pull on it with medium force at the angle it is oriented.
Dominic DeSantis
772 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2016 Member of UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 161
