HP Envy dv7t-7200 Service Cover Replacement
  1. HP Envy dv7t-7200 Service Cover Replacement, Battery: step 1, image 1 of 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Service Cover Replacement: step 2, image 1 of 3 HP Envy dv7t-7200 Service Cover Replacement: step 2, image 2 of 3 HP Envy dv7t-7200 Service Cover Replacement: step 2, image 3 of 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Service Cover Replacement: step 3, image 1 of 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Service Cover Replacement, Service Cover: step 4, image 1 of 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Service Cover Replacement: step 5, image 1 of 2 HP Envy dv7t-7200 Service Cover Replacement: step 5, image 2 of 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
Krystal
882 Reputation
8 Guides authored
UW Tacoma, Team S3-G3, Liner Fall 2017 Member of UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 354
