HP EliteBook x360 830 G6 Cooling System Replacement
  1. HP EliteBook x360 830 G6 Cooling System Replacement, Unfasten the back cover: step 1, image 1 of 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: step 2, image 1 of 2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: step 2, image 2 of 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: step 3, image 1 of 2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: step 3, image 2 of 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: step 4, image 1 of 3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: step 4, image 2 of 3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: step 4, image 3 of 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: step 5, image 1 of 3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: step 5, image 2 of 3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: step 6, image 1 of 3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: step 6, image 2 of 3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: step 6, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  7. HP EliteBook x360 830 G6 Cooling System Replacement: step 7, image 1 of 3 HP EliteBook x360 830 G6 Cooling System Replacement: step 7, image 2 of 3 HP EliteBook x360 830 G6 Cooling System Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  8. HP EliteBook x360 830 G6 Cooling System Replacement: step 8, image 1 of 1
    • Separate the fan and cooling system from the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Bukari
97 Reputation
1 Guide authored
Gateway, Team 1-2, Saknee Fall 2021 Member of Gateway, Team 1-2, Saknee Fall 2021
GCC-SAKNEE-F21S1G2
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 1,101
