Introduction
If you find yourself needing to replace the motherboard for your HP Beats Special Edition 15-p390nr, this guide will help you do so.
Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
Once screws are removed you may now remove the optical drive.
Remove the hidden 3mm screw in the optical drive port.
Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
The shoulder caps are removable. Underneath there are 2 additional screws.
