HP Beats Special Edition 15-p390nr Keyboard Replacement
  1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Keyboard Replacement: step 2, image 1 of 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: step 2, image 2 of 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Keyboard Replacement: step 3, image 1 of 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: step 3, image 2 of 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Keyboard Replacement: step 4, image 1 of 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: step 4, image 2 of 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Keyboard Replacement: step 5, image 1 of 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: step 5, image 2 of 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Keyboard Replacement: step 6, image 1 of 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: step 6, image 2 of 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 37
All Time: 2,801
