Introduction
Go to step 1 ↓Is your HP 250 G7 running slowly, struggling with multitasking, or frequently maxing out memory usage? Upgrading the RAM can significantly improve performance. This guide will show you how to access and replace the memory module.
Before starting this repair, check the HP 250 G7 Troubleshooting pages to confirm that insufficient RAM is the cause of your performance issues.
To begin:
- Power off the laptop
- Disconnect anything plugged into the laptop
Safety Warnings:
- Disconnect the battery before touching internal components
- Avoid static discharge, as RAM is highly sensitive to ESD
- Do not use metal pry tools when opening the laptop
- Handle the RAM module by the edges to avoid damaging the contacts
RAM Specs:
Memory module, 8 GB
Memory module, 4 GB
Tools
Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
Flip the laptop so its underside is facing up.
Use a hair dryer to lightly heat the rubber feet.
Use a spudger to lift and remove the rubber feet.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Gently grasp the edges of the memory module and pull it away from the slot.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
