HP 15-ef1041nr SSD Replacement
    1. HP 15-ef1041nr SSD Replacement, Lower Case: step 1, image 1 of 3 HP 15-ef1041nr SSD Replacement, Lower Case: step 1, image 2 of 3 HP 15-ef1041nr SSD Replacement, Lower Case: step 1, image 3 of 3
      • Use an opening tool to remove the two rubber feet on the lower case.
      • If you intend to reuse the feet, first use a hair dryer to heat the feet and take care not to tear or warp the feet during removal.
      • Place the rubber strips off to the side with the stickey side up.
      Ask FixBot
    2. HP 15-ef1041nr SSD Replacement: step 2, image 1 of 3 HP 15-ef1041nr SSD Replacement: step 2, image 2 of 3 HP 15-ef1041nr SSD Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the following screws securing the lower case:
      • Six 2 mm x 6mm screws
      • Two 2.5 mm x 6 mm screws
      • Be sure to keep different screw size separated.
      Ask FixBot
    3. HP 15-ef1041nr SSD Replacement: step 3, image 1 of 3 HP 15-ef1041nr SSD Replacement: step 3, image 2 of 3 HP 15-ef1041nr SSD Replacement: step 3, image 3 of 3
      • Insert an iFixit opening tool into the seam betwen the keyboard area and bottom cover.
      • Using another iFixit opening tool, slide along the seam to unhook the clips.
      • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
      • Remove the lower case.
      Ask FixBot
    1. HP 15-ef1041nr SSD Replacement, Battery: step 4, image 1 of 2 HP 15-ef1041nr SSD Replacement, Battery: step 4, image 2 of 2
      • Remove the five 2 mm x 3 mm screws that secures the battery.
      • Use an opening tool to carefully lift the battery up.
      • At a 45 degree angle, pull the battery away from the motherboard.
      Ask FixBot
    1. HP 15-ef1041nr SSD Replacement, SSD: step 5, image 1 of 3 HP 15-ef1041nr SSD Replacement, SSD: step 5, image 2 of 3 HP 15-ef1041nr SSD Replacement, SSD: step 5, image 3 of 3
      • Remove the single 2 mm screw that secures the drive with a Phillips screwdriver.
      • Lift the drive up at a 45 degree angle and pull.
      Ask FixBot
    2. HP 15-ef1041nr SSD Replacement: step 6, image 1 of 2 HP 15-ef1041nr SSD Replacement: step 6, image 2 of 2
      • To reinsert the hard drive, start at a 45 degree angle and push the drive into the slot. A small amount of force is required.
      • Hold the stick down and secure the new SSD drive with a 2 mm screw.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 200
