HP 14-dq5043cl RAM Replacement
    1. HP 14-dq5043cl RAM Replacement, Lower Case: step 1, image 1 of 2 HP 14-dq5043cl RAM Replacement, Lower Case: step 1, image 2 of 2
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
      Ask FixBot
    2. HP 14-dq5043cl RAM Replacement: step 2, image 1 of 1
      • Remove the six M2XL6 Phillips screws that secure the lower case.
      Ask FixBot
    3. HP 14-dq5043cl RAM Replacement: step 3, image 1 of 3 HP 14-dq5043cl RAM Replacement: step 3, image 2 of 3 HP 14-dq5043cl RAM Replacement: step 3, image 3 of 3
      • Insert a nylon spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP 14-dq5043cl RAM Replacement, RAM: step 4, image 1 of 3 HP 14-dq5043cl RAM Replacement, RAM: step 4, image 2 of 3 HP 14-dq5043cl RAM Replacement, RAM: step 4, image 3 of 3
      • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • When released, the RAM modules will pop up at a slight angle.
      • Slide the RAM module straight out to remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
585 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 41
All Time: 313
