HP 14-cf2112wm RAM Replacement
    1. HP 14-cf2112wm RAM Replacement, Back Cover: step 1, image 1 of 1
      • Before you begin, shut down your laptop and disconnect all cables.
      • Turn the laptop over so the bottom case is facing up.
      Ask FixBot
    2. HP 14-cf2112wm RAM Replacement: step 2, image 1 of 2 HP 14-cf2112wm RAM Replacement: step 2, image 2 of 2
      • Use a spudger to pry under the end of the screw cover.
      • When the edge is lifted up, use your fingers to pull the rest of the strip off.
      • Try to keep the strip intact so you can replace it at reassembly.
      Ask FixBot
    3. HP 14-cf2112wm RAM Replacement: step 3, image 1 of 2 HP 14-cf2112wm RAM Replacement: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove six 6 mm screws from the back case.
      Ask FixBot
    4. HP 14-cf2112wm RAM Replacement: step 4, image 1 of 3 HP 14-cf2112wm RAM Replacement: step 4, image 2 of 3 HP 14-cf2112wm RAM Replacement: step 4, image 3 of 3
      • Use a pick or opening tool to pry along the edges of the back cover from the keyboard side of the laptop.
      • Be careful as the case edges are sharp.
      Ask FixBot
    5. HP 14-cf2112wm RAM Replacement: step 5, image 1 of 1
      • Lift the back cover off the laptop.
      Ask FixBot
    1. HP 14-cf2112wm RAM Replacement, Battery: step 6, image 1 of 3 HP 14-cf2112wm RAM Replacement, Battery: step 6, image 2 of 3 HP 14-cf2112wm RAM Replacement, Battery: step 6, image 3 of 3
      • Place your opened laptop on a flat surface.
      • Use a Phillips #1 screwdriver to remove the four Phillips 3.0 mm screws securing the battery.
      Ask FixBot
    2. HP 14-cf2112wm RAM Replacement: step 7, image 1 of 2 HP 14-cf2112wm RAM Replacement: step 7, image 2 of 2
      • Slide the battery out from the connector on the motherboard.
      Ask FixBot
    1. HP 14-cf2112wm RAM Replacement, RAM: step 8, image 1 of 2 HP 14-cf2112wm RAM Replacement, RAM: step 8, image 2 of 2
      • Pull the metal arms (located on both sides of the RAM stick) slightly away from it .
      • The RAM will pop up by a few millimeters.
      Ask FixBot
    2. HP 14-cf2112wm RAM Replacement: step 9, image 1 of 1
      • Gently slide the RAM stick from the socket.
      • Remove it at an angle and not straight up so you don't damage the socket.
      • After you slide the new RAM stick back into the socket, push it down and it will click into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Shishi Hu
817 Reputation
5 Guides authored
2 Guide Comments
how do you put back together specifically step 4
heple seple - Reply Share
Just pop it back on. It should click together when everything is in place. After that, just screw everything back.
Shishi Hu - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 90
All Time: 1,573
