HP 14-cf2112wm Battery Replacement
  1. HP 14-cf2112wm Battery Replacement, Back Cover: step 1, image 1 of 1
    • Before you begin, shut down your laptop and disconnect all cables.
    • Turn the laptop over so the bottom case is facing up.
  2. HP 14-cf2112wm Battery Replacement: step 2, image 1 of 2 HP 14-cf2112wm Battery Replacement: step 2, image 2 of 2
    • Use a spudger to pry under the end of the screw cover.
    • When the edge is lifted up, use your fingers to pull the rest of the strip off.
    • Try to keep the strip intact so you can replace it at reassembly.
  3. HP 14-cf2112wm Battery Replacement: step 3, image 1 of 2 HP 14-cf2112wm Battery Replacement: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove six 6 mm screws from the back case.
  4. HP 14-cf2112wm Battery Replacement: step 4, image 1 of 3 HP 14-cf2112wm Battery Replacement: step 4, image 2 of 3 HP 14-cf2112wm Battery Replacement: step 4, image 3 of 3
    • Use a pick or opening tool to pry along the edges of the back cover from the keyboard side of the laptop.
    • Be careful as the case edges are sharp.
  5. HP 14-cf2112wm Battery Replacement: step 5, image 1 of 1
    • Lift the back cover off the laptop.
  6. HP 14-cf2112wm Battery Replacement, Battery: step 6, image 1 of 3 HP 14-cf2112wm Battery Replacement, Battery: step 6, image 2 of 3 HP 14-cf2112wm Battery Replacement, Battery: step 6, image 3 of 3
    • Place your opened laptop on a flat surface.
    • Use a Phillips #1 screwdriver to remove the four Phillips 3.0 mm screws securing the battery.
  7. HP 14-cf2112wm Battery Replacement: step 7, image 1 of 2 HP 14-cf2112wm Battery Replacement: step 7, image 2 of 2
    • Slide the battery out from the connector on the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Shishi Hu
778 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 92
All Time: 900
