HMD Fusion Charging Board Replacement
  1. HMD Fusion Charging Board Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. HMD Fusion Charging Board Replacement, Remove the SIM card tray: step 2, image 1 of 3 HMD Fusion Charging Board Replacement, Remove the SIM card tray: step 2, image 2 of 3 HMD Fusion Charging Board Replacement, Remove the SIM card tray: step 2, image 3 of 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
  3. HMD Fusion Charging Board Replacement, Remove the back cover screws: step 3, image 1 of 3 HMD Fusion Charging Board Replacement, Remove the back cover screws: step 3, image 2 of 3 HMD Fusion Charging Board Replacement, Remove the back cover screws: step 3, image 3 of 3
    • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
    • Use your fingernails, or angled tweezers, to remove any stuck screws.
    • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
  4. HMD Fusion Charging Board Replacement: step 4, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $16.96
    Buy
    • During the next four steps, the remaining back cover screws might fall out unexpectedly.
    • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
  5. HMD Fusion Charging Board Replacement, Unclip the back cover: step 5, image 1 of 2 HMD Fusion Charging Board Replacement, Unclip the back cover: step 5, image 2 of 2
    • Flip your phone over so the screen is facing up.
    • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
  6. HMD Fusion Charging Board Replacement: step 6, image 1 of 3 HMD Fusion Charging Board Replacement: step 6, image 2 of 3 HMD Fusion Charging Board Replacement: step 6, image 3 of 3
    • Slide the opening pick along the left edge to begin unclipping the back cover.
  7. HMD Fusion Charging Board Replacement: step 7, image 1 of 3 HMD Fusion Charging Board Replacement: step 7, image 2 of 3 HMD Fusion Charging Board Replacement: step 7, image 3 of 3
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
  8. HMD Fusion Charging Board Replacement: step 8, image 1 of 3 HMD Fusion Charging Board Replacement: step 8, image 2 of 3 HMD Fusion Charging Board Replacement: step 8, image 3 of 3
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
  9. HMD Fusion Charging Board Replacement, Disconnect the battery: step 9, image 1 of 3 HMD Fusion Charging Board Replacement, Disconnect the battery: step 9, image 2 of 3 HMD Fusion Charging Board Replacement, Disconnect the battery: step 9, image 3 of 3
  10. HMD Fusion Charging Board Replacement, Disconnect the power button: step 10, image 1 of 3 HMD Fusion Charging Board Replacement, Disconnect the power button: step 10, image 2 of 3 HMD Fusion Charging Board Replacement, Disconnect the power button: step 10, image 3 of 3
    • Use a spudger to pry up and disconnect the power button press connector.
    • Remove the back cover.
  11. HMD Fusion Charging Board Replacement, Remove the loudspeaker screws: step 11, image 1 of 2 HMD Fusion Charging Board Replacement, Remove the loudspeaker screws: step 11, image 2 of 2
    • Be careful not to puncture or damage the battery with your tool during the rest of this guide.
    • Use a T3 Torx screwdriver to remove the three 3.4 mm‑long screws securing the loudspeaker.
    • One of the screws on the loudspeaker may be covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
  12. HMD Fusion Charging Board Replacement, Remove the loudspeaker: step 12, image 1 of 3 HMD Fusion Charging Board Replacement, Remove the loudspeaker: step 12, image 2 of 3 HMD Fusion Charging Board Replacement, Remove the loudspeaker: step 12, image 3 of 3
    • Use your fingers to lift the loudspeaker out of the frame by its metal bracket.
    • Remove the loudspeaker.
  13. HMD Fusion Charging Board Replacement, Disconnect the charging board: step 13, image 1 of 3 HMD Fusion Charging Board Replacement, Disconnect the charging board: step 13, image 2 of 3 HMD Fusion Charging Board Replacement, Disconnect the charging board: step 13, image 3 of 3
    • Slide one arm of a pair of tweezers under the metal neck of the black antenna cable's connector head, near the center of the board.
    • Lift straight up to disconnect the cable.
    • Repeat for the white antenna cable.
    • To reconnect the cable, hold the metal head over its socket and press down with the flat end of a spudger—it should snap into place. If it's not connecting, reposition the head and try again.
  14. HMD Fusion Charging Board Replacement: step 14, image 1 of 2 HMD Fusion Charging Board Replacement: step 14, image 2 of 2
    • Use a spudger to pry up and disconnect the interconnect cable press connector.
  15. HMD Fusion Charging Board Replacement: step 15, image 1 of 3 HMD Fusion Charging Board Replacement: step 15, image 2 of 3 HMD Fusion Charging Board Replacement: step 15, image 3 of 3
    • Move the interconnect cable press connector toward the battery to keep it out of the way of the charging board in the next step.
    • You can use tape with light adhesive (such as painter's tape) to keep the cable out of the way.
  16. HMD Fusion Charging Board Replacement: step 16, image 1 of 2 HMD Fusion Charging Board Replacement: step 16, image 2 of 2
    • Use tweezers, or your fingers, to move the two antenna cables out of their slots near the top edge of the charging board.
  17. HMD Fusion Charging Board Replacement, Remove the charging board screw: step 17, image 1 of 2 HMD Fusion Charging Board Replacement, Remove the charging board screw: step 17, image 2 of 2
    • Use a T3 Torx screwdriver to remove the 3.3 mm‑long screw securing the charging board.
  18. HMD Fusion Charging Board Replacement, Remove the charging board: step 18, image 1 of 3 HMD Fusion Charging Board Replacement, Remove the charging board: step 18, image 2 of 3 HMD Fusion Charging Board Replacement, Remove the charging board: step 18, image 3 of 3
    • The top edge of the charging board is adhered to the frame.
    • Insert the flat end of a spudger under the top left edge of the charging board, next to the antenna cable connectors.
    • Slide the spudger under the charging board to separate the adhesive.
  19. HMD Fusion Charging Board Replacement: step 19, image 1 of 3 HMD Fusion Charging Board Replacement: step 19, image 2 of 3 HMD Fusion Charging Board Replacement: step 19, image 3 of 3
    • Lift the charging board out of the frame and remove it.
    • During reassembly, insert the USB-C port into its slot before pressing the charging board flat to the frame.
Alex Diaz-Kokaisl
212,689 Reputation
1,039 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,610 Guides authored
1 Guide Comment
If i have tried to fix the phone by self-repair but the phone still not working, where or who i need to refer?
Khairul Ridhuan - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 68
All Time: 1,439
