Grip Tape Application
  1. Grip Tape Application, Grip Tape Application: step 1, image 1 of 1
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Grip Tape Application: step 2, image 1 of 1
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Grip Tape Application: step 3, image 1 of 2 Grip Tape Application: step 3, image 2 of 2
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Grip Tape Application: step 4, image 1 of 2 Grip Tape Application: step 4, image 2 of 2
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Grip Tape Application: step 5, image 1 of 3 Grip Tape Application: step 5, image 2 of 3 Grip Tape Application: step 5, image 3 of 3
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Grip Tape Application: step 6, image 1 of 1
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. Grip Tape Application: step 7, image 1 of 1
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. Grip Tape Application: step 8, image 1 of 2 Grip Tape Application: step 8, image 2 of 2
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 other people completed this guide.
Jared Stine
800 Reputation
3 Guides authored
Cal Poly, Team 6-32, Regan Fall 2012 Member of Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 35
All Time: 8,238
