Skateboard Trucks Replacement
    1. Skateboard Trucks Replacement, Trucks: step 1, image 1 of 2 Skateboard Trucks Replacement, Trucks: step 1, image 2 of 2
      • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
      • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
      Ask FixBot
    2. Skateboard Trucks Replacement: step 2, image 1 of 1
      • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
      Ask FixBot
    3. Skateboard Trucks Replacement: step 3, image 1 of 1
      • Hand tighten the nut hardware onto all four bolts.
      Ask FixBot
    4. Skateboard Trucks Replacement: step 4, image 1 of 1
      • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
      • Repeat steps 1 - 6 to install the second truck.
      Ask FixBot
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
2 other people completed this guide.
Cameron Nye
79 Reputation
1 Guide authored
Cal Poly, Team 6-32, Regan Fall 2012 Member of Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 127
All Time: 14,105
