Google Pixel 10 Pro Fold Outer Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
10
Past 7 Days:
80
Past 30 Days:
272
All Time:
1,348
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the outer screen in your Google Pixel 10 Pro Fold.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Google Pixel 10 Pro Fold Outer Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone and completely power it down.
      Ask FixBot
    1. Google Pixel 10 Pro Fold Outer Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
      • Insert an opening pick into the gap.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. Google Pixel 10 Pro Fold Outer Screen Replacement, Separate the adhesive: step 3, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Separate the adhesive: step 3, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Separate the adhesive: step 3, image 3 of 3
      • During the next three steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
      • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
      • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
      Ask FixBot
    3. Google Pixel 10 Pro Fold Outer Screen Replacement: step 4, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 4, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 4, image 3 of 3
      • Slide the pick around the top right corner and along the top edge of the screen.
      Ask FixBot
    4. Google Pixel 10 Pro Fold Outer Screen Replacement: step 5, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 5, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 5, image 3 of 3
      • Slide your pick down the left edge and around the bottom left corner to separate the remaining adhesive.
      Ask FixBot
    5. Google Pixel 10 Pro Fold Outer Screen Replacement: step 6, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 6, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 6, image 3 of 3
      • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
      • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
      • Lift the left edge of the screen and swing it over the right edge of the phone, like opening a book.
      • Prop up the screen with your suction handle or a clean, sturdy object.
      Ask FixBot
    6. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display cable bracket screws: step 7, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display cable bracket screws: step 7, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • While the Pixel 10 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP driver to remove the three screws securing the display cable bracket:
      • One 1.8 mm‑long screw
      • Two 2.5 mm‑long screws
      Ask FixBot
    7. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display bracket: step 8, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display bracket: step 8, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display bracket: step 8, image 3 of 3
      • Use the point of a spudger to pry up the display bracket and release its clip from the bottom edge of the frame.
      • Remove the display bracket.
      Ask FixBot
    8. Google Pixel 10 Pro Fold Outer Screen Replacement, Disconnect the screen: step 9, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Disconnect the screen: step 9, image 2 of 2
      • When disconnecting press connectors, pry only at the gold outlines on the logic board.
      • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
      • Use the point of a spudger to pry up the display cable press connector.
      Ask FixBot
    9. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the screen: step 10, image 1 of 1
      • Lift the screen off the frame and remove it.
      Ask FixBot
    1. Google Pixel 10 Pro Fold Outer Screen Replacement, End of disassembly: step 11, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      Ask FixBot
    1. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the old adhesive: step 12, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the old adhesive: step 12, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the old adhesive: step 12, image 3 of 3
      • Use a spudger, or your fingers, to remove the old outer screen adhesive on the frame.
      • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
      • If your new outer screen has a liner covering the front camera cutout, remove it now.
      • If your new outer screen comes with pre-installed adhesive, skip here. Otherwise, follow the guide normally to install new adhesive.
      Ask FixBot
    2. Google Pixel 10 Pro Fold Outer Screen Replacement, Compare your new adhesive: step 13, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Compare your new adhesive: step 13, image 2 of 2
      • Before removing any liners, check if the outer screen adhesive matches the frame.
      • The clear liner should face the frame.
      Ask FixBot
    3. Google Pixel 10 Pro Fold Outer Screen Replacement, Apply the new adhesive: step 14, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Apply the new adhesive: step 14, image 2 of 2
      • Peel away the top half of the new adhesive strip from its clear liner and keep the liner folded before continuing.
      Ask FixBot
    4. Google Pixel 10 Pro Fold Outer Screen Replacement: step 15, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement: step 15, image 2 of 2
      • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
      • Align the top half of the adhesive over the frame, using the corners as reference points.
      • Place the adhesive on the frame.
      Ask FixBot
    5. Google Pixel 10 Pro Fold Outer Screen Replacement: step 16, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 16, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 16, image 3 of 3
      • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
      Ask FixBot
    6. Google Pixel 10 Pro Fold Outer Screen Replacement: step 17, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 17, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 17, image 3 of 3
      • While peeling away the rest of the clear liner, slowly lay the adhesive over the perimeter of the phone.
      Ask FixBot
    7. Google Pixel 10 Pro Fold Outer Screen Replacement: step 18, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement: step 18, image 2 of 2
      • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
      Ask FixBot
    8. Google Pixel 10 Pro Fold Outer Screen Replacement: step 19, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement: step 19, image 2 of 2
      • Use the point of a spudger to pry up the segmented tab on the bottom edge of the large blue liner.
      Ask FixBot
    9. Google Pixel 10 Pro Fold Outer Screen Replacement: step 20, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 20, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 20, image 3 of 3
      • Lift the tab and peel off the large blue liner to expose the secondary liner.
      • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
      Ask FixBot
    1. Google Pixel 10 Pro Fold Outer Screen Replacement, Reconnect the outer screen: step 21, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Reconnect the outer screen: step 21, image 2 of 2
      • Support the screen with your hand or prop it up on something sturdy.
      • Reconnect the outer screen cable press connector.
      Ask FixBot
    2. Google Pixel 10 Pro Fold Outer Screen Replacement, Place the display bracket: step 22, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Place the display bracket: step 22, image 2 of 2
      • Place the display bracket over its spot on the frame.
      Ask FixBot
    3. Google Pixel 10 Pro Fold Outer Screen Replacement: step 23, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement: step 23, image 2 of 2
      • Use the point of a spudger to press down the display bracket and slide its clip under the bottom edge of the frame.
      Ask FixBot
    4. Google Pixel 10 Pro Fold Outer Screen Replacement, Install the display bracket screws: step 24, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Install the display bracket screws: step 24, image 2 of 2
      • Use a Torx Plus 3IP driver to install the three screws securing the display cable bracket:
      • If your new outer screen comes with pre-installed adhesive, remove the liner to expose its adhesive and skip here.
      Ask FixBot
    5. Google Pixel 10 Pro Fold Outer Screen Replacement, Expose the adhesive: step 25, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Expose the adhesive: step 25, image 2 of 2
      • Use tweezers to grip the pull tab of the secondary liner at the bottom left corner of the phone.
      Ask FixBot
    6. Google Pixel 10 Pro Fold Outer Screen Replacement: step 26, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 26, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 26, image 3 of 3
      • Peel the liner from the left and top edge of the phone.
      Ask FixBot
    7. Google Pixel 10 Pro Fold Outer Screen Replacement: step 27, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 27, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement: step 27, image 3 of 3
      • While holding the screen over the frame, peel the liner from the right and bottom edge of the frame and expose the adhesive.
      Ask FixBot
    8. Google Pixel 10 Pro Fold Outer Screen Replacement, Secure the outer screen: step 28, image 1 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Secure the outer screen: step 28, image 2 of 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Secure the outer screen: step 28, image 3 of 3
      • Align the outer screen over the frame and press it into place.
      Ask FixBot
    9. Google Pixel 10 Pro Fold Outer Screen Replacement: step 29, image 1 of 2 Google Pixel 10 Pro Fold Outer Screen Replacement: step 29, image 2 of 2
      • Press along the perimeter of the outer screen to adhere it to the frame.
      • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
      • Let the phone sit a few hours for the adhesive to cure.
      Ask FixBot
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 10 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
250,935 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 80
Past 30 Days: 272
All Time: 1,348
