Google Pixel XL Opening Procedure
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Google Pixel XL Opening Procedure, Google Pixel XL Opening Procedure: step 1, image 1 of 1
    • Remove the following screws that secure the midframe to the back:
    • Seven black 4 mm T5 screws
    • Two silver 3 mm T5 screws
  2. Google Pixel XL Opening Procedure: step 2, image 1 of 1
    • The midframe is held tightly in place by plastic clips which push into the edge of the back case.
  3. Google Pixel XL Opening Procedure: step 3, image 1 of 3 Google Pixel XL Opening Procedure: step 3, image 2 of 3 Google Pixel XL Opening Procedure: step 3, image 3 of 3
    • Find the small notch in the bottom left corner of the frame and insert an opening pick.
    • Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
  4. Google Pixel XL Opening Procedure: step 4, image 1 of 3 Google Pixel XL Opening Procedure: step 4, image 2 of 3 Google Pixel XL Opening Procedure: step 4, image 3 of 3
    • Insert a separate opening pick into the right edge of the phone, near the bottom.
    • Slowly push the pick upwards along the seam until the first clip pops free.
    • Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
    • Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
  5. Google Pixel XL Opening Procedure: step 5, image 1 of 2 Google Pixel XL Opening Procedure: step 5, image 2 of 2
    • Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
    • Slowly slide the pick past the clip to disengage it from the frame.
    • At this point, the right edge of the midframe should be free from the case. If it isn't, slide an opening clip up and down along the right edge.
  6. Google Pixel XL Opening Procedure: step 6, image 1 of 3 Google Pixel XL Opening Procedure: step 6, image 2 of 3 Google Pixel XL Opening Procedure: step 6, image 3 of 3
    • Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
    • When the left edge feels loose, stop hinging and lift the midframe upwards.
    • Remove the midframe.
    • To reinstall the midframe, align it to the case, then squeeze around the perimeter until all the clips snap back into position. When properly done, the midframe should lie flat.
Arthur Shi
254,609 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 132
