Google Pixel XL Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Google Pixel XL Battery Replacement, Battery: step 1, image 1 of 1
      • Power off your device.
      • Eject the SIM card tray by inserting a SIM card tool (or the end of a paperclip) into the hole in the SIM tray. Press firmly to eject the tray.
      • Slide the SIM card tray out of the phone.
      • Take care not to lose the SIM card, which is small and may fall out unexpectedly.
      Ask FixBot
    2. Google Pixel XL Battery Replacement: step 2, image 1 of 3 Google Pixel XL Battery Replacement: step 2, image 2 of 3 Google Pixel XL Battery Replacement: step 2, image 3 of 3
      • Heat the perimeter of the display using an iOpener, hair dryer, or heat gun.
      • Heat will help soften the adhesive securing the display, making it easier to separate. The display should be heated until it's slightly too hot to touch, for roughly two minutes. Use extra caution if working with a heat gun, as applying too much heat will permanently damage the OLED panel.
      • Use a suction cup to lift one edge of the screen just slightly, creating a small gap between the display and the frame of the phone.
      • Insert an opening pick into the gap.
      • Carefully slide the opening pick around the perimeter of the phone to separate the adhesive.
      • If you plan to re-use the display, don't insert the opening pick more than a few millimeters into the phone, or you may damage the OLED panel underneath the glass.
      • You may need to slide the pick around the perimeter multiple times to fully separate the adhesive. Work slowly and carefully until the display begins to come free.
      • Gently lift the display, but don't try to fully detach it yet—it is still connected by a ribbon cable lying underneath.
      Ask FixBot
    3. Google Pixel XL Battery Replacement: step 3, image 1 of 1
      • Use the T5 screwdriver to remove the two black 4mm screws which hold the screen connector shield in place.
      • Gently remove the metal screen connector shield.
      Ask FixBot
    4. Google Pixel XL Battery Replacement: step 4, image 1 of 2 Google Pixel XL Battery Replacement: step 4, image 2 of 2
      • Be careful not to damage the connector when performing this step.
      • Use the spudger or your fingernail to lift off the connector that holds the screen in place.
      • Lift off the display assembly completely and place it off to the side.
      • Gently scrape any remaining adhesive from your phone. Use a small amount of high concentration isopropyl alcohol (at least 90%) to clean the frame and prep it for the new screen adhesive.
      • The replacement adhesive should only be applied to the edges of the frame, but may come with the center filled in.
      • To remove the unnecessary center section of the adhesive strip, carefully peel away the perforated rectangle in middle of the white backing. At the same time, peel up the black adhesive underneath the white backing.
      • Only adhesive for the edges of the frame should remain.
      Ask FixBot
    5. Google Pixel XL Battery Replacement: step 5, image 1 of 2 Google Pixel XL Battery Replacement: step 5, image 2 of 2
      • Remove the seven black 4mm T5 screws.
      • Remove the two silver 3mm T5 screws which secure the mid frame assembly.
      • There will be clicks as you take the mid frame out of the phone due to the clips that normally hold it in place.
      • Lift the mid frame from the rear casing by pulling it upwards.
      Ask FixBot
    6. Google Pixel XL Battery Replacement: step 6, image 1 of 2 Google Pixel XL Battery Replacement: step 6, image 2 of 2
      • Disconnect the battery by using a spudger to pry up the battery connector.
      • A large daughterboard interconnect cable covers the battery. Before removing the battery, you will need to detach this cable and move it out of the way.
      • Peel back the tape covering the lower end of the cable to reveal where it connects to the daughterboard. Then, use your spudger to pry up the cable and disconnect it.
      • If desired, you can do the same at the top end of the cable to detach and remove it completely, or you may simply bend the cable gently out of the way while you remove the battery.
      Ask FixBot
    7. Google Pixel XL Battery Replacement: step 7, image 1 of 3 Google Pixel XL Battery Replacement: step 7, image 2 of 3 Google Pixel XL Battery Replacement: step 7, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Pull on the perforated tab at the top of the battery and peel it down the center of the phone.
      • Grab the tab firmly and pull with firm, steady pressure. Slowly, the adhesive securing the battery will give way and the battery should come free.
      • If the tab rips or you are unable to free the battery, you may use a plastic card (such as a credit card) or spudger to pry up the battery.
      • Use extreme care when handling the battery. A puncture or bend could result in a fire.
      • To install a new battery:
      • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should go around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
      • Press the battery firmly into place for 5-10 seconds.
      Ask FixBot
Andrew Ferguson
1,403 Reputation
3 Guides authored
Cal Poly, Team S13-G4, Forte Spring 2017 Member of Cal Poly, Team S13-G4, Forte Spring 2017
CPSU-FORTE-S17S13G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 190
