Google Pixel Watch 2 Screen Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
87
Past 30 Days:
302
All Time:
2,398
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace a cracked, broken, or non-responsive screen on your Google Pixel Watch 2.
Replacing the screen requires removing the battery. If the battery gets bent, creased, or deformed in any way during removal, you'll need to replace it.
You'll need replacement adhesive glue to seal your watch during reassembly.
Tools
    1. Google Pixel Watch 2 Screen Replacement, Prepare your watch for disassembly: step 1, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Prepare your watch for disassembly: step 1, image 2 of 2
      • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
      • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
      Ask FixBot
    2. Google Pixel Watch 2 Screen Replacement, Remove both watch bands: step 2, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Remove both watch bands: step 2, image 2 of 2
      • Remove both watch bands by pressing the release button and sliding the band out of its groove.
      Ask FixBot
    3. Google Pixel Watch 2 Screen Replacement, Put your watch in the vise: step 3, image 1 of 1
      • Inserting a tool between the screen and frame is very difficult. Using a vise to secure the frame makes it significantly easier.
      • Secure your watch with a small vise so the jaws go into the watch band grooves on the frame.
      • If your vice has sharp or metal jaws, consider wrapping the frame in a thin cloth to prevent scratching or damaging the frame.
      Ask FixBot
    4. Google Pixel Watch 2 Screen Replacement, Safety precautions: step 4, image 1 of 1
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
      • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Wear gloves to protect yourself.
      Ask FixBot
    5. Google Pixel Watch 2 Screen Replacement, Heat the screen adhesive: step 5, image 1 of 1
      • Very strong adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
      • Use a hair dryer or heat gun to heat the right edge of screen around the watch crown until it's slightly too hot to touch.
      • Be careful not to heat the screen more than this, as it may damage the screen and/or battery.
      Ask FixBot
    6. Google Pixel Watch 2 Screen Replacement, Insert an iFlex: step 6, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Insert an iFlex: step 6, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Insert an iFlex: step 6, image 3 of 3
      • Insert the tip of an iFlex between the screen and frame just below the watch crown (opposite the side button).
      • This is very difficult and will take multiple attempts. If the screen cools down, apply more heat and try again.
      • Rotate the iFlex so its longer edge is between the screen and frame.
      Ask FixBot
    7. Google Pixel Watch 2 Screen Replacement, Separate the screen adhesive: step 7, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Separate the screen adhesive: step 7, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Separate the screen adhesive: step 7, image 3 of 3
      • Hold the iFlex at a slight upward angle and slide it clockwise around the perimeter of the watch to separate the adhesive. Stop when you reach the side button.
      • Don't slide farther than this or you'll damage the screen cable.
      Ask FixBot
    8. Google Pixel Watch 2 Screen Replacement, Remove your watch from the vise: step 8, image 1 of 1
      • Remove your watch from the vise.
      Ask FixBot
    9. Google Pixel Watch 2 Screen Replacement, Disassembly information: step 9, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Disassembly information: step 9, image 2 of 2
      • Throughout the rest of your repair:
      • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
      • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
      Ask FixBot
    10. Google Pixel Watch 2 Screen Replacement, Swing open the screen: step 10, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Swing open the screen: step 10, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Swing open the screen: step 10, image 3 of 3
      E6000 Adhesive Glue
      $2.99
      Buy
      • Be careful not to strain the screen cable during the rest of your repair.
      • Swing open the screen and put it in an upright position next to the watch crown.
      • If the screen feels stuck, go back around the perimeter and carefully separate any remaining adhesive with the iFlex. Be very careful not to damage the screen cable near the crown.
      • During reassembly:
      • This is a good point to plug in and test your watch before sealing it up. Be sure to power it down completely before you continue working.
      • Use a spudger and tweezers to remove all the old screen adhesive from the frame and screen. Then, clean up any adhesive residue with high‑concentration (>90%) isopropyl alcohol and a cotton swab.
      • You'll need to seal your watch with strong adhesive glue. Apply the glue to the perimeter of the frame and firmly press the screen into place.
      • Most strong adhesive glues have a long curing time—read the instructions for proper use.
      Ask FixBot
    1. Google Pixel Watch 2 Screen Replacement, Unfasten the vibration motor cover: step 11, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Unfasten the vibration motor cover: step 11, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a 1IP Torx Plus screwdriver to remove the 2 mm‑long screw securing the vibration motor press connector cover.
      • While the Pixel Watch 2 uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
      Ask FixBot
    2. Google Pixel Watch 2 Screen Replacement, Peel up the vibration motor cable tape: step 12, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Peel up the vibration motor cable tape: step 12, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Peel up the vibration motor cable tape: step 12, image 3 of 3
      • Tape secures the vibration motor cable and its cover to the battery.
      • Be careful not to puncture the battery—it can leak dangerous chemicals and catch fire.
      • Use a pair of blunt nose tweezers to grip the vibration motor press connector cover.
      • Gently peel up the tape until the vibration motor cable is uncovered.
      • During reassembly, use the flat end of a spudger to push the black cover tape back into place.
      Ask FixBot
    3. Google Pixel Watch 2 Screen Replacement, Disconnect the vibration motor: step 13, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Disconnect the vibration motor: step 13, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Disconnect the vibration motor: step 13, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the vibration motor press connector.
      • During reassembly, use the flat end of a spudger to reconnect the press connector.
      Ask FixBot
    4. Google Pixel Watch 2 Screen Replacement, Unfasten the vibration motor: step 14, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Unfasten the vibration motor: step 14, image 2 of 2
      • Use a 1IP Torx Plus screwdriver to remove the two screws securing the vibration motor:
      • One 2 mm‑long screw
      • One 3 mm‑long screw, also securing a grounding bracket
      Ask FixBot
    5. Google Pixel Watch 2 Screen Replacement, Remove the grounding bracket: step 15, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Remove the grounding bracket: step 15, image 2 of 2
      • Use blunt nose tweezers to lift the grounding bracket out of its recess and remove it.
      • During reassembly, use the smaller alignment cutout to orient the bracket.
      Ask FixBot
    6. Google Pixel Watch 2 Screen Replacement, Remove the vibration motor: step 16, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Remove the vibration motor: step 16, image 2 of 2
      • Remove the vibration motor.
      Ask FixBot
    1. Google Pixel Watch 2 Screen Replacement, Unfasten the battery: step 17, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Unfasten the battery: step 17, image 2 of 2
      • Use a 1IP Torx Plus screwdriver to remove the two screws securing the battery:
      Ask FixBot
    2. Google Pixel Watch 2 Screen Replacement, Remove the grounding bracket: step 18, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Remove the grounding bracket: step 18, image 2 of 2
      Ask FixBot
    3. Google Pixel Watch 2 Screen Replacement, Pry up the battery: step 19, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Pry up the battery: step 19, image 2 of 2
      • Light adhesive secures the battery in place.
      • Insert the flat end of a spudger under the top edge of the battery.
      • Pry the battery up to separate the adhesive.
      • Don't try to remove the battery yet, as it's still connected to the watch with a delicate cable.
      Ask FixBot
    4. Google Pixel Watch 2 Screen Replacement, Reposition the battery: step 20, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Reposition the battery: step 20, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Reposition the battery: step 20, image 3 of 3
      • Lift the battery out of its recess and set it next to your watch so you can access the battery connector.
      • Be careful not to strain the battery cable.
      Ask FixBot
    5. Google Pixel Watch 2 Screen Replacement, Unfasten the battery connector bracket: step 21, image 1 of 2 Google Pixel Watch 2 Screen Replacement, Unfasten the battery connector bracket: step 21, image 2 of 2
      • Use a 1IP Torx Plus screwdriver to remove the two 2 mm‑long screws securing the battery connector bracket.
      Ask FixBot
    6. Google Pixel Watch 2 Screen Replacement, Remove the battery cable bracket: step 22, image 1 of 1
      • Use tweezers to remove the battery connector bracket.
      Ask FixBot
    7. Google Pixel Watch 2 Screen Replacement, Disconnect the battery: step 23, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Disconnect the battery: step 23, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Disconnect the battery: step 23, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      • During reassembly, hold the battery above the watch while reconnecting it. Make sure the press connector is oriented so the cable is facing outward.
      Ask FixBot
    8. Google Pixel Watch 2 Screen Replacement, Remove the battery: step 24, image 1 of 1
      • Remove the battery.
      • If your battery is bent, creased, or deformed in any way, don't reuse it. Replace it with a new battery.
      • If your replacement battery doesn't come installed in a bracket, transfer the bracket from your old battery to the new one.
      Ask FixBot
    1. Google Pixel Watch 2 Screen Replacement, Disconnect the screen: step 25, image 1 of 3 Google Pixel Watch 2 Screen Replacement, Disconnect the screen: step 25, image 2 of 3 Google Pixel Watch 2 Screen Replacement, Disconnect the screen: step 25, image 3 of 3
      • Gently slide the flat end of a spudger under the screen cable.
      • Lift the cable to disconnect it.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    2. Google Pixel Watch 2 Screen Replacement, Remove the screen: step 26, image 1 of 1
      • Remove the screen.
      Ask FixBot
2 other people completed this guide.
Spencer Day
208,368 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,955 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 87
Past 30 Days: 302
All Time: 2,398
