Shop the Holiday Gift Guide
Google Pixel Display Adhesive Installation
Views: 21K
View statistics:
Past 24 Hours:
3
Past 7 Days:
40
Past 30 Days:
135
All Time:
20,902
Comments: 20
18 comments on steps, 2 guide comments.
Go to guide comments
Completed: 48
48 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to correctly apply replacement adhesive to your Pixel or Pixel XL display after a repair.
Some replacement displays do not come with an earpiece speaker grille. If your replacement screen doesn't have one, be sure to transfer the grille from your old display to the new one before you install it. Alternatively, you can buy a new one here.
Before you begin, you should have already removed your Pixel’s display assembly and set it aside. Detailed instructions for each model can be found at the following links:
Google Pixel
Google Pixel XL
Parts
Tools
    1. Google Pixel Display Adhesive Installation, Display Adhesive: step 1, image 1 of 3 Google Pixel Display Adhesive Installation, Display Adhesive: step 1, image 2 of 3 Google Pixel Display Adhesive Installation, Display Adhesive: step 1, image 3 of 3
      • Peel away and remove all the old display adhesive from the body of your phone.
      • Use the point of your spudger to scour away and remove any lingering adhesive.
      • Using metal tools can lead to scratching the glass!
      • If you are reinstalling your existing display, remove all the old adhesive from that as well.
      • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
      • While high-concentration isopropyl alcohol is generally safe for use with electronics, it can wear away the foam padding on the midframe. Be careful as you clean the narrow edges of the frame.
      Ask FixBot
    2. Google Pixel Display Adhesive Installation: step 2, image 1 of 3 Google Pixel Display Adhesive Installation: step 2, image 2 of 3 Google Pixel Display Adhesive Installation: step 2, image 3 of 3
      • The replacement adhesive should only be applied to the edges of the frame, but may come with the center filled in.
      • To remove the unnecessary center section of the adhesive strip, carefully peel away the center portion of both the white (paper) and black (adhesive) layers, starting with the U-shaped cutout.
      Ask FixBot
    3. Google Pixel Display Adhesive Installation: step 3, image 1 of 2 Google Pixel Display Adhesive Installation: step 3, image 2 of 2
      • Peel off and discard the remaining paper liner, exposing the adhesive underneath.
      Ask FixBot
    4. Google Pixel Display Adhesive Installation: step 4, image 1 of 2 Google Pixel Display Adhesive Installation: step 4, image 2 of 2
      • Hold the adhesive sheet with the exposed adhesive facing down, and carefully align it into the lower edge of the phone.
      • Make sure the adhesive sheet is oriented correctly, with the rectangular cutout for the earpiece speaker at the top.
      • When it's correctly aligned, lower the rest of the adhesive sheet into the phone.
      Ask FixBot
    5. Google Pixel Display Adhesive Installation: step 5, image 1 of 3 Google Pixel Display Adhesive Installation: step 5, image 2 of 3 Google Pixel Display Adhesive Installation: step 5, image 3 of 3
      • Firmly press the adhesive into place.
      • You can use the flat end of a spudger to press along the edges and other hard-to-reach areas.
      Ask FixBot
    6. Google Pixel Display Adhesive Installation: step 6, image 1 of 2 Google Pixel Display Adhesive Installation: step 6, image 2 of 2
      • Peel off and discard the plastic liner, exposing the display adhesive.
      Ask FixBot
    7. Google Pixel Display Adhesive Installation: step 7, image 1 of 2 Google Pixel Display Adhesive Installation: step 7, image 2 of 2
      • Once the new adhesive is exposed, do your best not to touch it—either with your hand, or the display. If you can, try to hold the display up and away from the rest of the phone (as shown in the step photo) while performing this step.
      • Re-attach the display cable connector.
      • Screw the connector bracket back in place.
      • Power on your phone to make sure your repair was successful.
      • Do not remove or adjust the display cable while the phone is powered on.
      Ask FixBot
    8. Google Pixel Display Adhesive Installation: step 8, image 1 of 1
      • Once you are sure the display is functioning properly, carefully align it with the chassis and firmly press it into place.
      • To help the display adhesive bond more securely, heat the perimeter of the display and then place the phone face-up under a heavy stack of books for 30 minutes.
      Ask FixBot
48 other people completed this guide.
Author
with
Taylor Dixon
73,290 Reputation
94 Guides authored
2 Guide Comments
What is the included tesa tape for?
Koelton Carere - Reply Share
The Tesa tape is to adhere the battery to the frame. You don't want anything moving around inside your phone--that can stress, damage, or disconnect ribbon connectors.
David Bauman - Reply Share
Past 24 Hours: 3
Past 7 Days: 40
Past 30 Days: 135
All Time: 20,902
