Google Pixel C Speaker Replacement
  1. Google Pixel C Speaker Replacement, Screen: step 1, image 1 of 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Speaker Replacement: step 2, image 1 of 2 Google Pixel C Speaker Replacement: step 2, image 2 of 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Speaker Replacement: step 3, image 1 of 2 Google Pixel C Speaker Replacement: step 3, image 2 of 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Speaker Replacement: step 4, image 1 of 2 Google Pixel C Speaker Replacement: step 4, image 2 of 2
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
  5. Google Pixel C Speaker Replacement, Speaker: step 5, image 1 of 1
    • Locate the thin black speakers along the right and left sides of the tablet.
    • The longer speaker is secured by two different types of screws, while the shorter one is secured by two of the same type of screw.
  6. Google Pixel C Speaker Replacement: step 6, image 1 of 1
    • Use the Phillips #000 screwdriver to remove the three 4.2mm screws
    • Use the same screwdriver to remove the 2.5mm screw as well.
  7. Google Pixel C Speaker Replacement: step 7, image 1 of 3 Google Pixel C Speaker Replacement: step 7, image 2 of 3 Google Pixel C Speaker Replacement: step 7, image 3 of 3
    • Locate the two circular metal caps that are attached to the short speaker via a small cable and gently pull them out of the device
    • Locate and detach the third cable cap that is attached to the longer speaker.
    • The third cable runs along the upper edge of the device, and is secured down with adhesive.
  8. Google Pixel C Speaker Replacement: step 8, image 1 of 1
    • Slide both speakers out from the edges of the device.
  9. Google Pixel C Speaker Replacement: step 9, image 1 of 3 Google Pixel C Speaker Replacement: step 9, image 2 of 3 Google Pixel C Speaker Replacement: step 9, image 3 of 3
    • Locate the red and black twisted wires.
    • Use a spudger to pry under the cable and pop it free from the attachment, fully detaching the speaker from the device.
Isabelle Tang
225 Reputation
2 Guides authored
Cal Poly, Team S21-G4, Livingston Spring 2017 Member of Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Members
11 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 837
