Introduction
This guide will outline how to replace the speakers should they be faulty, broken, or produce fuzzy audio.
Use a heat gun to melt the adhesive that holds the screen to the device
Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
Use the Phillips #000 screwdriver to remove the three 4.2mm screws
Use the same screwdriver to remove the 2.5mm screw as well.
Locate the two circular metal caps that are attached to the short speaker via a small cable and gently pull them out of the device
Locate and detach the third cable cap that is attached to the longer speaker.
Locate the red and black twisted wires.
Use a spudger to pry under the cable and pop it free from the attachment, fully detaching the speaker from the device.
