Google Pixel 9 Pro Fold Back Cover Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 9 Pro Fold Back Cover Removal, Prepare your phone for disassembly: step 1, image 1 of 1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone and completely power it down.
      Ask FixBot
    1. Google Pixel 9 Pro Fold Back Cover Removal, Insert an opening pick: step 2, image 1 of 3 Google Pixel 9 Pro Fold Back Cover Removal, Insert an opening pick: step 2, image 2 of 3 Google Pixel 9 Pro Fold Back Cover Removal, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
      • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
      Ask FixBot
    2. Google Pixel 9 Pro Fold Back Cover Removal, Separate the back cover adhesive: step 3, image 1 of 3 Google Pixel 9 Pro Fold Back Cover Removal, Separate the back cover adhesive: step 3, image 2 of 3 Google Pixel 9 Pro Fold Back Cover Removal, Separate the back cover adhesive: step 3, image 3 of 3
      • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
      • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
      • Remove the suction handle from the back cover.
      • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
      Ask FixBot
    3. Google Pixel 9 Pro Fold Back Cover Removal: step 4, image 1 of 3 Google Pixel 9 Pro Fold Back Cover Removal: step 4, image 2 of 3 Google Pixel 9 Pro Fold Back Cover Removal: step 4, image 3 of 3
      • Continue sliding the pick around the top left corner and across the top edge of the back cover.
      Ask FixBot
    4. Google Pixel 9 Pro Fold Back Cover Removal: step 5, image 1 of 3 Google Pixel 9 Pro Fold Back Cover Removal: step 5, image 2 of 3 Google Pixel 9 Pro Fold Back Cover Removal: step 5, image 3 of 3
      • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
      • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
      Ask FixBot
    5. Google Pixel 9 Pro Fold Back Cover Removal: step 6, image 1 of 3 Google Pixel 9 Pro Fold Back Cover Removal: step 6, image 2 of 3 Google Pixel 9 Pro Fold Back Cover Removal: step 6, image 3 of 3
      • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
      • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
      • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
      • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
      Ask FixBot
    6. Google Pixel 9 Pro Fold Back Cover Removal, Remove the top bracket screw: step 7, image 1 of 2 Google Pixel 9 Pro Fold Back Cover Removal, Remove the top bracket screw: step 7, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
      Ask FixBot
    7. Google Pixel 9 Pro Fold Back Cover Removal, Remove the top bracket: step 8, image 1 of 2 Google Pixel 9 Pro Fold Back Cover Removal, Remove the top bracket: step 8, image 2 of 2
      • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
      • Remove the top bracket.
      Ask FixBot
    8. Google Pixel 9 Pro Fold Back Cover Removal, Disconnect the back cover cable: step 9, image 1 of 2 Google Pixel 9 Pro Fold Back Cover Removal, Disconnect the back cover cable: step 9, image 2 of 2
      • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
      • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
      • Pry up and disconnect the back cover cable.
      Ask FixBot
    9. Google Pixel 9 Pro Fold Back Cover Removal, Remove the back cover: step 10, image 1 of 1
      • Lift the back cover off the frame and remove it.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
250,095 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 206
